Route Optimization API - Api Changes 1.38.0 (09.01.2026)
Posted: Fri Jan 09, 2026 12:38 pm
Route Optimization API1.38.0FEATURE09.01.2026Increased the maximum resources per vehicle to 2.
Re: Route Optimization API - Api Changes 1.38.0 (09.01.2026)
Posted: Fri Jan 09, 2026 1:02 pm
OpenAPI Update Analysis (v1.36 → v1.38)
I compared the two OpenAPI specs you provided (1.36-openapi.json vs 1.38-openapi.json) and here’s what changed.
1) Endpoints / Paths
✅ No new or removed endpoints.
All paths remain unchanged between 1.36 and 1.38.
➡️ So this update is mainly about new response structures / schema extensions, not API routes.
2) New Schemas (Classes) introduced in 1.38
Version 1.38 adds six new component schemas:
  • AssignedResource
  • AssignedResourceCosts
  • LegLoad
  • ResultCosts
  • RouteCosts
  • RouteDurations
📌 Interpretation:
This introduces a more structured cost + duration reporting layer, plus resource assignments and leg-level load breakdowns.
3) Existing Schemas extended (new properties)
Several existing schemas gained new properties in 1.38.
✅ Metrics (extended)
New fields:
  • numberOfScheduledOrders
  • costs
➡️ Meaning: metrics now not only report distances/durations/etc., but also how many orders were actually scheduled, plus a structured cost object (ResultCosts).
✅ RouteMetrics (extended)
New fields:
  • numberOfOrders
  • durations
  • costs
➡️ Meaning: route-level metrics now become more granular by including:
  • order count per route
  • a structured duration breakdown (RouteDurations)
  • structured cost breakdown (RouteCosts)
✅ Leg (extended)
New field:
  • loads
➡️ Meaning: each leg can now include load data, using the new schema LegLoad.
This is useful if you want leg-by-leg capacity utilization instead of only route-level totals.
✅ OptimizationResult (extended)
New field:
resources
➡️ Meaning: the optimization result can now include resource assignment information, likely represented via the new schema AssignedResource.
✅ Summary (quick forum-style)
✅ New Schemas
  • AssignedResource
  • LegLoad
  • ResultCosts
  • RouteCosts
  • RouteDurations
✅ New Properties in Existing Schemas
  • Metrics: numberOfScheduledOrders, costs
  • RouteMetrics: numberOfOrders, durations, costs
  • Leg: loads
  • OptimizationResult: resources
❌ No path/endpoint changes
No routes were added or removed.
⚠️ Client Impact / Compatibility Notes
This is non-breaking in typical JSON parsing scenarios, but:
✅ If your client / DTO model is strict (e.g., schema validation, strict deserialization), you may need to update to accept:
  • OptimizationResult.resources
  • Leg.loads
  • new nested cost/duration structures in Metrics and RouteMetrics
