How to model vehicle with TRAILER / without TRAILER?
Posted: Wed Jan 07, 2026 12:09 pm
The following usecase is quite generic within tour optimization and therefore I would like to describe how to model this:
  • We have a fleet with multiple vehicles we can utilize.
  • For some of the vehicles we can consider an optional trailer which means:
    • If a trailer is attached to the vehicle it's COSTS and CAPACITIES change.
    • The optimization should check whether a trailer is meaningful or not for a certain vehicle.
  • Bonus: some orders may prohibit a trailer vehicle to serve them.
Now here's the proper modeling approach - based on a single vehicle named "TheVehicle4711" (If you get this for a single vehicle you can easily derive how to use this in multiple vehicles):
  • Define a so-called Resource "Resource-4711" which is free of costs and limited to maximumVehicles=1:
      "id" :"TheVehicle4711",
      "minimumBufferDuration" : 0,
      "constraints" : {
         "maximumVehicles" : 1
      "costs": null,
      "categories" : ["Cat-Res-4711"]
  • Create two alternative vehicle objects : one with the trailer based properties (higher capacity, higher costs)
    • Code: Select all
        "id" : "vehicle-4711-no-trailer",
        "requiredResourceCategories": [ "Cat-Res-4711" ],
    • Code: Select all
        "id" : "vehicle-4711-with-trailer",
        "categories": ["hasTrailer"]
  • For the bonus requirement: forbid "hasTrailer" vehicles to serve certain orders:
    • use constraints.combinations.orderVehicle:
          "combinations": {
            "orderVehicle": [
               "type": "FORBIDDEN_COMBINATION",
               "orderCategory": "no-trailer",
               "vehicleCategory" : "hasTrailer"
    • Mark the critical orders as "no-trailer" category:
         "id" ; "order-23",
         "properties": {
            "categories" : [ "no-trailer" ]
