Routing extreme: SpeedPatterns over time
Posted: Tue Sep 08, 2015 11:44 am
HI there,
for those who are dealing with time dependent routings: I created a little testclient that may be helpful for evaluation of time dependencies. It computes the route with a fixed waypointlist and an interval of various daytimes.
Besides the changing routing geometries in the map it visualizes the dynamic character of those routes via some histograms:
left diagram: the current route's speed pattern<br />right diagram: red line change of driving period over all routes, white line change of distance over all routes
The reason why the difference between various scenarios is so big is the Sierichstraße in Hamburg: it is a dynamic one-way street that changes directions twice a day (04:00am and 12:00pm).
I also created a little movie... it is available here (to be deleted from the cloud when I need space):
https://ptvbox.ptvgroup.com/public.php? ... 2a17244500
Feedback is welcome,
Once the testclient has a proper level I can provide it here.
Re: Routing extreme: SpeedPatterns over time
Posted: Thu Nov 24, 2016 12:29 pm
Here's another test output based on SpeedPatterns
Driving times and distances in 1hour steps
Posted: Fri Dec 16, 2016 8:10 am
I attached the sample executeable below so if you want to play with it JUST DO IT!
  • It also works with xServer INTERNET, just set the URLs and provide your token
  • Choose valid coordinates for CENTER and WAYPOINTS (MERCATOR coordinate format)
  • Further configuration parameters are the time behaviour (STart=ReferenceTime and Endtime and timestep)
As always: feedback is welcome!
Regards Bernd
