Access tourplanning response in xTour2
Posted: Mon Jun 17, 2024 5:02 am
by Prakash
As I can fetch tour planning response using "storedRequestId" for unschedule analysis. This response was available for a certain time.
How long is the tour planning result accessible in xTour2” ?
Where can I configure this value?
Prakash
Re: Access tourplanning response in xTour2
Posted: Mon Jun 17, 2024 8:37 am
Hello Prakash,
check the section lifetime of stored requests in the Session Storage chapter:
Lifetime of stored requests
Requests in the session storage cannot be deleted via the PTV xServer API. However, there are two general parameters in the PTV xServer configuration file to limit the life span of the stored requests. These parameters are core.session.retentionTime and core.session.cleanupInterval, see Server Configuration.
Each stored request has a time stamp containing its creation time. A ToursInExecutionRequest resets the time stamp of the corresponding stored request to the current server time. A cleanup task is started once after every cleanup interval and deletes all requests whose time stamps are older than the retention time.
Posted: Tue Dec 16, 2025 4:58 pm
by CAPcargo
Is there any maximum how long we can store the request?
Posted: Wed Dec 17, 2025 11:36 pm
Check the config values mentioned above. You can increase them if needed. Is that what you were looking for?
Posted: Fri Dec 19, 2025 8:32 am
by CAPcargo
I'd rather like to know if it is possible to have the request stored for 3days or even more?
