Successor of xTour1.toursMustFitIntoSingleOperatingInterval
recently I've been asked for the xTour2 parameter that replaces xtour1's BaseVehicle property:
toursMustFitIntoSingleOperatingInterval boolean If set to true, tours must fit into a single operating interval. This attribute is ignored for the method planOvernightTours because this use case must consider several operating intervals.
As an example, users modell a vehicle with the 5 operating intervals "monday to friday, 9am to 5pm"...
So here's how Alex and I discussed the two potential values:
  • true : that's the default behaviour. Simply use 5 operating intervals. As a trip has to be contained in a single interval this will ensure the driver returns home at the end of the interval.
    :!: Attention: if your planning approach doesn't use trip delimiters (depots), e.g. because you exclusively plan VisitOrders, this may return single day tours only...
  • false :
    • use one large global interval from "monday 9am" to "friday 5pm"
    • besides the breaks during the day just create further BreakIntervals with fixed length for each night:
       "interval": { "$type": "StartEndInterval", "start" : ..monday.. 5pm,    "end" :  ..tuesday.. 9am  },
        "breakTime" : 57600
       "interval": { "$type": "StartEndInterval", "start" : ..tuesday.. 5pm,    "end" :  ..wednesday.. 9am  },
        "breakTime" : 57600
      }, and so forth
Re: Successor of xTour1.toursMustFitIntoSingleOperatingInterval
Here' also an important sidenote, triggered by parties dealing with service technicians who usually make use of the V
com.ptvgroup.xserver.xtour.VisitOrder class.
  • As VisitOrders are not linked to Depots.
  • As there are no depots there are no trip delimiting elements (check Tours and Trips). No delimiter means : vehicles serves only one trip
  • As trips must fit into an interval there's only one day utilized, if you model the driver with "one interval per day".
:!: You could tackle this effect by using com.ptvgroup.xserver.xtour.TransportOrder instead.
