accessing roadeditor layer failed after updating map
Posted: Tue May 28, 2024 9:23 am
Closed: the resolution was to install the TLN version of the map instead of the stock version
Im am using an external library to connect to PTV xRoute server 1.30.
After updating the map from 'PTV Europe City Map Premium 2021.1H' to 'PTV Europe City Map Premium 2024.2H' I receive the following error when requesting any distance calculation:
Invalid Response Code :
Upon some investigating I noticed that changing the profile used for the calculation circumvents this problem.
However I am not sure what the difference is between the old and new profile, and ideally I would like to use the same profile as before the map upgrade. As I have no idea how to tackle this issue any help is welcome!
The old profile used before the map upgrade was '40T.xml' and after encountering the error after the map upgrade I changed it to a default 'TruckFast.mxl' (see attatchments).
<soap:Body>
<soap:Fault>
<faultcode>soap:2580</faultcode>
<faultstring>accessing roadeditor layer failed, probably the specified layer name does not
exist, or no layer name has been specified</faultstring>
<detail>
<ns3:XRouteException xmlns:ns6="http://exception.core.jabba.ptvag.com"
xmlns:ns4="http://types.xroute.xserver.ptvag.com"
xmlns:ns3="http://xroute.xserver.ptvag.com"
xmlns:ns2="http://baseservices.service.jabba.ptvag.com"
xmlns:ns1="http://common.xserver.ptvag.com"
xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com">
<ns6:stackElement className="com.ptvag.xserver.xroute.XRouteException" errorKey="2580"
message="accessing roadeditor layer failed, probably the specified
layer name does not exist, or no layer name has been specified">
<ns6:cause xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ns6:wrappedContext xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns6:stackElement>
</ns3:XRouteException>
</detail>
</soap:Fault>
</soap:Body>
</soap:Envelope>
