resources... where to drop them?
Posted: Tue Jan 09, 2024 11:01 am
Hi Oliver,
one of my partners is cleaning up his xServer.NET driven projects. Looks liek some files are not located properly after an update:
In the pastThese files have been located in the programm folder AND in the subfolder DE.
Where should they be located from now on?
Re: resources... where to drop them?
Posted: Tue Jan 09, 2024 3:01 pm
by Oliver Heilig
Here the the list of the assemblies contained in the binarie zip or nuget package.
de/Ptv.XServer.Controls.Map.resources.dllSatellite assembly containing localized texts in german. For example: This will display "Kartenebenen" instead of "Layers" in the layers list when running on a german Windows. If the DLL is missing the default (english) texts are used.
Ptv.Components.Projections.dllThis assembly contains the components for reprojection with PROJ.4. It should only be required when using specific coordinate systems.
Ptv.XServer.Controls.Map.dllThe map control.
Ptv.XServer.Controls.Map.XmlSerializers.dllThis assembly contains pre-compiled code for SOAP/XML, used by the xMap-1 access. If it is not present, this code is created at runtime.
The .pdb and .xml files contain information for debugging and api-documentation.
