xServer.NET 1.4 available for download (August 2015)
Posted: Thu Aug 06, 2015 12:34 pm
Hello together,
we published a new version of xServer.NET on our http://xserver.ptvgroup.com/en-uk/nc/de ... omer-area/
Feel free to downbload it... it is available at the customer area (requires login).
PTV xServer .NET
Copyright (c) 2014 PTV Group, Karlsruhe, Germany.
What is PTV xServer .NET?
PTV xServer .NET is a supplement to the PTV xServer providing an abstraction
and convenience layer for integrating PTV xServer into applications based on
the Microsoft .NET Framework.
Important Notes
For license details, please refer to the file LICENSE.TXT, which should have
been provided with this distribution.
If you intend to install PTV xServer .NET into a path which requires administrative
rights, you have to execute the setup with elevated permissions.
Prerequisites
- At least Windows Vista, Windows 7 or Windows 8 is recommended.
- At least Microsoft .NET 3.5 for running the demos provided through our
Demo Center.
- At least Visual Studio C# 2008 Express Edition for developing applications
based on PTV xServer .NET. With regards to the WPF integration and the
overall development experience we recommend at least Visual Studio 2010.
- The demos provided require internet access as they make use of PTV xServer
running on a PTV test system. Usually you'll set up your own servers when
developing applications based on PTV xServer / PTV xServer .NET.
- All third-party libraries used by the SDK and the Demo Center are included
in the SDK package.
First Steps
- For a first glance start our Demo Center that is provided in compiled form.
The Demo Center requires at least Microsoft .NET 3.5 and internet access to
run properly.
- For developing applications using PTV xServer .NET, the source code of the
Demo Center, provided in the folder .\source, along with our use case
documentation may be a good source of information.
- For details on PTV xServer, please refer to the PTV xServer documentation.
Visual Studio Toolbox
- Toolbox registration has to be done for every user separately.
- Toolbox registration is done by the setup of PTV xServer .NET for Microsoft
Visual Studio 2008, 2010, 2012 and 2014 installations. Due to limitations of the
Microsoft Visual Studio Express editions the PTV xServer .NET Toolbox Installer
is not capable of adding toolbox items in this case.
You can add the toolbox items manually as follows:
* Open Microsoft Visual Studio Express
* If desired create a new tab
* Drag&Drop the 'Ptv.XServer.Controls.Map.dll' located in '<INSTALL_PATH>/lib'
into the desired tab.
To remove the toolbox items just delete the corresponding entries in the toolbox list.
- If for any reason Toolbox registration must be updated or renewed, please use
our registration utility provided in the folder .\tools.
Release Notes
Version 1.4.0.0 (2015/07/30)
Controls:
- New interface IToolTips, which can be implemented by layers, to provide textual
information around a dedicated location (commonly the mouse position).
The UntiledLayer class implements this interface.
- The layer responsible for showing content of Web Map Services is integrated into
the Ptv.XServer.Controls.Map.dll. It allows re-projections of returned images to
achieve a matching of the content provided by accompanying layers.
New Demo Center use cases, which are also available by the click-once-demo
from http://xserverinternet.azurewebsites.net/xserver.net/:
- Feature Layer: By means of this tool, street attributes can be activated for
route calculation and shown in the map. Five different types are integrated
by this use case, eventually restricted by the availability in the used map:
- Traffic incidents
- Truck attributes
- Preferred routes
- Restriction zones
- Speed patterns
Demo Center:
- A short user introduction is shown at start-up time.
- The user can open and manipulate multiple use cases concurrently, which may result
in a confusing GUI. By means of a new reset button, all these use cases can be
converted into its initial state.
Version 1.3.0.0 (2014/11/21)
Controls:
- The Map Controls are ready for access of PTV xServer internet, i.e. PTV xServer
functionality is available via Cloud.
- New property XMapStyle in interface IMap added. It determines the coloring
of the background layer containing the town, street and areas like seas,
forests, industrial areas and so on. Internally, the provided style name is
textually extended to meet the requirements of the xServer configuration.
- A new layer is implemented which shows the Here Satellite View. It is an
alternative to the still available, but no longer integrated Bing aerials
in DemoCenter.
- At some certain zoom levels, the map images appeared blurred in former
versions; this bug is fixed.
- The gadgets integrated in the Map Control (for example the layers gadget
or the zoom slider) do no longer raise any exception, when they are integrated
in a docking container, which may cause some re-initialization of these gadgets.
A proper releasing of all previously needed objects before re-initialization
prevents the exceptional situation.
Visual Studio integration:
- For WinForms and WPF different Map Controls are provided. In former versions,
only the WinForms map is integrated into the toolbox of Visual Studio. In the
new version, also the WPF Map is integrated.
- XServer connection: At run-time a server URL and an optional token can be
specified to demonstrate how different PTV xServers are addressed to achieve
their functionality – especially the PTV xServer internet, which is provided via
Azure currently. Because the latter needs a token, a time-limited one is provided
for testing. The source code of the Demo Center enforces a programmer to specify
the current test token or, if available, the purchased version.
- To select geographical objects for further operations, a client-side selection
mechanism is shown in the same-named use case.
- The Tour Planning use case demonstrates via randomly generated tour points,
depots and orders, how to access the xTour functionality in an asynchronous way.
A progress bar and status quo texts are shown without blocking the user interface.
- By positioning the way points of a route via drag & drop, the corresponding
source code outlines the necessary steps.
- The Shape Layer in the use case ‘Different Shapes’ is extended by pie-chart
objects and each object can be underlined by textual labels.
- The layer containing the Bing Aerials is still available, but in the Demo Center
this layer is replaced by the Here Satellite View layer.
- The previously available use cases Marker and Tours and Stops are removed because
their functionality is part of the new use cases mentioned above.
Version 1.2.0.0 (2013/06/12)
Breaking Changes
- Map: IUntiledProvider.GetImageStream has been modified to support double
precision coordinates.
Unless a custom provider has been implemented in your application, this
change is of minor importance. Where a custom provider has been implemented,
integer type casts may get you to the previous behaviour. This change was
made in order to provide extended 'deep zoom support' through the label
layer.
- Projections: OGC_GEODECIMAL has been renamed to OG_GEODECIMAL to conform
with the PTV xServer naming. OGC_GEODECIMAL has been kept as an alias in the
Registry; however, Ptv.Components.Projections.CoordinateReferenceSystem.XServer
no longer defines OGC_GEODECIMAL as an attribute. In addition, some managed
transformations have been refactored. These refactoring remain imperceptible
if the transformations are properly accessed via CoordinateTransformation.Get.
- XMap layers: Interface of class XMapLayerFactory has been refactored
concerning all variants of InsertXMapBaseLayers. Instead of specifying different
combinations of XMapServer settings in varying parameters, these settings are
concentrated in a new class XMapMetaInfo. An instance of this class is used to
specify the XMapServer settings, which can be reused in calls to methods
XMapLayerFactory.InsertRoadEditor and XMapLayerFactory.InsertPOI.
Others
- Introduced a utility class for calculating the distance between two points
- Optimized performance for xSaaS access (or xServer https access, respectively)
- Changed Shape Layer to simplify implementation of custom shape types
- Enhanced TiledLayer-API for implementation of custom providers
- Provided the ability to incorporate arbitrary xMap Server layers into the map.
A conceptual page in PTV xServer .NET's help file provides additional documentation.
- Added three new samples demonstrating drag&drop routing, tooltip display for xMap
Server content and different rendering approaches (tiled, non-tiled bitmap, vector)
- Fixed a panning problem that occurred on lower zoom levels
- Fixed layer ordering issue when using ILayer.Priority
- Complemented the interoperability "How Tos" with a C++/MFC sample
- Added a new property 'LazyUpdate' to the Shape Layer to improve performance for
a large number of complex shapes
Version 1.1.0.0 (2013/03/11)
Breaking Changes
- <none>
Others
- Added support for zoom levels up to level 23.
- Improvements for Shape Layer API.
- Added INotifyPropertyChanged for ILayer and INotifyCollectionChanged for LayersCollection.
- Added support for xSaaS.
- Added sample for ActiveX-Integration.
- Some minor fixes for rendering glitches.
Version 1.0.0.0 (2012/12/18)
First Release
Known Issues of Current Release
- Visual Studio versions have to be installed completely and have to be started
once before running the PTV xServer .NET setup. Otherwise the toolbox installer
which is integrated in the PTV xServer .Net setup will not work properly.
- The provided Demo Center solution can only be opened with Visual Studio 2010 or
higher. All components can nevertheless be used together with Visual Studio 2008.
Using Visual Studio 2008, you can open the csproj file.
- Printing the code samples of the documentation via the provided link currently
does not work.
- Changing the visibility of a map gadget at runtime has no effect on the map display.
Currently, you can only change these settings at design time.
- Using the shape layer for a large number of dynamic objects (or complex objects) may
cause delays in the map's responsiveness. Unfortunately there is a limitation in
.NET's WPF layer that cannot be fixed to number. If you experience performance problems
when using the shape layer we recommend to build an own rendering layer. Please refer
to the documentation for additional information.
