Comparison of world map with europe city map
Posted: Thu Nov 30, 2023 9:03 am
by YellowFoxNP
what are the differences between the Europe City map (Here) and the World Map (Here) in terms of
- performance
- system requirements
- and coverage?
For example, are the truck attributes for Germany the same in the Europe and World map?
Nico (YellowFox)
Re: Comparison of world map with europe city map
Posted: Thu Nov 30, 2023 10:18 am
Hi Nico,
Thanks for this trigger! I will forward this thread tom some experts in the different domains (data/coverage, modules, system administration...) and request their feedback.
My personal expectation is:
- The HERE World map is a superposition of the continental HERE maps. Therefore the TruckAttributes in both maps should be equal in European countries compared to the World aequivalent.
- No direct impact on xCluster2, xTour2, xLoad2 as these modules do not access the map data by themselves. So I'd say we need to check this in xRoute2, xDima2, xData2, xLocate2.
- We offer some abbreviation mechanisms to refer to sub-units of the world map. I recommend that you check this article about country codes. It explains how to apply codes such as "zz-eur" to restrict a routings search space to European countries. We also use the abbreviations for the search graphs in the HPR context.
- There's also a com.ptvgroup.xserver.xlocate.SearchOptions parameter in xLocate 2 that speeds up the indexed search in a significant manner (unfortunately does not support the abbreviations mentioned above).
- Of course you will need more disk space and memory.
Here are also some related forum posts:
Posted: Tue Dec 19, 2023 4:19 pm
Here's some feedback from Nazir:
We do not use continent specific map, we use World Map for all xServer2 environments, so on Cloud and on Datacenter environments.
If the customer runs xServer application on a local environment, having a plane map folder locally would be the best way for them. Because, it's easier to patch and faster to process. We can create a guide for installation.
System requirements depend on usage, however for running a World Map on a Linux machine we recommend
- At least same amount of cores as modules ( if there are 8 modules overall, then at least 8 available cores)
- At least 60GB of RAM for World Map (Our least used environment has 100GB RAM)
- Faster SSD storage for World Map (at least 250 GB)
On the other hand, I cannot give you an exact comparison of maps. But, we can try both - World and Continent map in the same environment with the same requests to find out the performance difference.
I hope the information above helps you a bit. Please, do not hesitate to ask more questions if you have any.
