Detour
Posted: Thu Jul 30, 2015 9:40 am
Hello guys!
I require some explanation again
We plan between the following two points: [47.374779, 19.048795 - HU] & [47.425411, 19.064196 - HU]
As a result we receive a route which has a huge detour around the centrum of the city. I've checked the segment attributes and I noticed on the last section theres are some DIR_OPT_COND_MALUS5|0=120 restrictions, which means the road is closed for vehicles heavier than the given weight except for residential vehicles. In our case the vehicle is residental (as we transport goods there), so we can use these segments.
BUT if that is the case, why dont we use the following road which is much shorter and doesn't take the detour? I've received that alternative route with RoadEditor layer turned off, but I don't see any other limitation other than that DIR_OPT_COND_MALUS5|0=120 limit.
The question is: If there are the same kind of restrictions on both routes, why can't we use the shorter one with RoadEditor options?
Is there a calculation on how much distance we have to drive on these restricted segments? And in the first case this distance is shorter from the north side?
I've attached the currently used profile.
The map is 2015.2H EuroPremium
The RoadEditor layer is: TruckAttributes_EUR
RoadEditor additional options: MAX_WEIGHT=40000,MAX_HEIGHT=400,MAX_WIDTH=250,MAX_LENGTH=17500,MAX_AXLE_LOAD=1050
Thank you,
Zsolt
Thank you,
Zsolt
