Increase the penalty of entering a prohibited road
VeeTennis
Post by VeeTennis »
We have had an interesting case where a vehicle was guided through a prohibited pedestrian area.
Our guess is that the issue appeared due to the timed vehicle length restriction. As there was no way for PTV to calculate the route on a non-restricted area (the length restriction is on the starting point, end point and the surrounding area), the algorithm looked for the shortest route across the prohibited area, therefore, a route through the prohibited pedestrian area was calculated.
Is it possible to somehow increase the penalty of entering a prohibited road, so that the algorithm would calculate an alternative path which would go through the length restriction, rather than the prohibited road?
A reference screenshot is attached.
Request body:
   "waypoints":[
         "$type":"OffRoadWaypoint",
         "location":{
            "offRoadCoordinate":{
               "y":"45.496174363",
               "x":"9.2396971959"
         "location":{
               "y":45.49395975417229,
               "x":9.279456214560605
   "routeOptions":{
      "timeConsideration":{
         "$type":"SnapshotTimeConsideration",
         "referenceTime":"2023-10-02T09:00:00.000Z"
      "geographicRestrictions":{
         "prohibitedCountries":[
            "BY",
            "RU"
         "searchSpaceBounds":{
            "restrictionMode":"AUTOMATIC"
      "currency":"EUR"
   "resultFields":{
      "polyline":true,
      "encodedPath":false,
      "eventTypes":[
         "ROUTE_VIOLATION_EVENT"
      "toll":{
         "enabled":true
      "legs":{
         "enabled":true,
         "tollSummary":true
      "report":true,
      "tourReport":true,
      "waypoints":true,
      "segments":{
         "enabled":true,
         "polyline":true,
         "descriptors":true,
         "roadAttributes":true,
         "featureThemeIds":[
            "PTV_TruckAttributes"
   "requestProfile":{
      "featureLayerProfile":{
         "themes":[
               "id":"PTV_TruckAttributes",
               "enabled":true
      "routingProfile":{
         "searchSpace":{
            "heuristicAggressiveness":0
         "linking":{
            "maximumDistanceToSegment":50000,
            "minimumNetworkClass":0,
            "maximumNetworkClass":7
         "course":{
            "distanceTimeWeighting":"0",
            "combinedTransport":{
               "boatPenalty":2501,
               "railPenalty":2501
      "vehicleProfile":{
         "engine":{
            "emissionStandardEU":"EURO_6",
            "lowEmissionZoneTypes":"DE_GREEN"
         "legalCondition":{
            "isDelivery":true,
            "isEmergency":false
         "dimensions":{
            "height":500,
            "length":1300,
            "width":null
         "weight":{
            "emptyWeight":0,
            "loadWeight":414404,
            "totalPermittedWeight":414404
         "load":{
            "loadType":"GOODS",
            "tunnelRestrictionCode":"NONE",
            "hazardousGoodsTypes":"NONE"
And resulting road violations:
      "$type":"RouteViolationEvent",
      "eventType":"ROUTE_VIOLATION_EVENT",
      "startsAt":"2023-10-02T09:00:03.120Z",
      "coordinate":{
         "x":9.2398659757,
         "y":45.496196493
      "distanceFromStart":13,
      "travelTimeFromStart":3.12,
      "violationType":"FEATURE",
      "violatedFeature":{
         "themeId":"PTV_TruckAttributes",
         "attributes":[
               "key":"maxHeight",
               "value":"445"
      "accessType":"PASS"
      "coordinate":{
         "x":9.2398659757,
         "y":45.496196493
      "violatedFeature":{
         "attributes":[
               "key":"maxLength",
               "value":"1200"
               "key":"hasTrailer",
               "value":"0"
      "accessType":"PASS"
      "startsAt":"2023-10-02T09:00:22.390Z",
      "coordinate":{
         "x":9.240058081,
         "y":45.495367461
      "distanceFromStart":104,
      "travelTimeFromStart":22.39,
      "violationType":"PROHIBITED",
      "accessType":"ENTER",
      "relatedEventIndex":3
      "startsAt":"2023-10-02T09:08:02.390Z",
      "coordinate":{
         "x":9.2460702841,
         "y":45.491638088
      "distanceFromStart":1254,
      "travelTimeFromStart":482.39,
      "accessType":"EXIT",
      "relatedEventIndex":2
      "coordinate":{
         "x":9.2460702841,
         "y":45.491638088
      "violatedFeature":{
         "attributes":[
               "key":"maxLength",
               "value":"1200"
               "key":"hasTrailer",
               "value":"0"
      "relatedEventIndex":5
      "startsAt":"2023-10-02T09:08:40.200Z",
      "coordinate":{
         "x":9.2476706547,
         "y":45.491304555
      "distanceFromStart":1433,
      "travelTimeFromStart":520.2,
      "violatedFeature":{
         "attributes":[
               "key":"maxLength",
               "value":"1200"
               "key":"hasTrailer",
               "value":"0"
      "relatedEventIndex":4
Re: Increase the penalty of entering a prohibited road
Hi Vytennis,
can we look into this together?
I'd like to check this via a teams session... Please book a slot through the booking portal
