you can determine the time zone for each stop and segment along the route.
The time zone for xServers is defined as UTC-offset. If you know the offset to UTC at a given position, you know the timezone of this position.
First you need correctly installed Feature Layer PTV_TimeZones - thats the basic Featue Layer used by all time dependend Feature Layers (PTV_TrafficIncidents, PTV_SpeedPatterns, ...)
Then you just have to set the [ResultListOption] <utcOffsets="true">
For Example I also used PTV_SpeedPaterns in this request:
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<calculateRoute xmlns="http://types.xroute.xserver.ptvag.com" xmlns:ns2="http://baseservices.service.jabba.ptvag.com" xmlns:ns3="http://common.xserver.ptvag.com" xmlns:ns4="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns5="http://exception.core.jabba.ptvag.com" xmlns:ns6="http://xroute.xserver.ptvag.com">
<ArrayOfWaypointDesc_1>
<ns6:WaypointDesc fuzzyRadius="0" linkType="NEXT_SEGMENT">
<ns6:wrappedCoords>
<ns3:Point>
<ns3:point y="49.6092" x="6.0723"/>
</ns3:Point>
</ns6:wrappedCoords>
<ns6:wrappedSegmentID xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
</ns6:WaypointDesc>
<ns6:wrappedCoords>
<ns3:Point>
<ns3:point y="49.60169" x="6.10155"/>
</ns3:Point>
</ns6:WaypointDesc>
</ArrayOfWaypointDesc_1>
<ArrayOfRoutingOption_2>
<ns6:RoutingOption value="2014-11-05T17:00:00+01:00" parameter="START_TIME"/>
</ArrayOfRoutingOption_2>
<ArrayOfExceptionPath_3 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/>
<ResultListOptions_4 featureDescriptions="true" totalRectangle="false" boundingRectanglesOffset="0" boundingRectanglesC="0" tollManoeuvres="false" manoeuvreGroups="false" urbanManoeuvres="false" brunnelManoeuvres="false" manoeuvreAttributes="false" segmentAttributes="false" segments="true" dynamicInfo="true" detailLevel="STANDARD" polygon="true" binaryPathDesc="false" nodes="false" texts="false" manoeuvres="false" utcOffsets="true"/>
<CallerContext_5>
<ns2:wrappedProperties>
<ns2:CallerContextProperty value="OG_GEODECIMAL" key="CoordFormat"/>
<ns2:CallerContextProperty value="WKB" key="ResponseGeometry"/>
<ns2:CallerContextProperty value="truckslow" key="Profile"/>
<ns2:CallerContextProperty value="<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation="http:///xroute/schema/XRouteProfile.xsd"><Common language='en' majorVersion='1' minorVersion='0'/><Routing majorVersion='2' minorVersion='0'><Course><AdditionalDataRules enabled='true'/></Course></Routing><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true'/><Themes><Theme id='PTV_SpeedPatterns' enabled='true'><FeatureDescription includeLanguageCode='true'><Property id='message' included='true'/></FeatureDescription></Theme></Themes></FeatureLayer></Profile>" key="ProfileXMLSnippet"/>
</ns2:wrappedProperties>
</CallerContext_5>
</calculateRoute>
</soap:Body>
</soap:Envelope>
<ns3:wrappedSegments>
<ns3:RouteListSegment utcOffset="60" countryCode="" iuCode="52" vNorm="0" nC="CITY_ROAD" accDist="157" accTime="18" dirInfoIdx="-1" streetNameIdx="-1" streetNoIdx="-1" nodeC="2" firstNodeIdx="0" polyC="3" firstPolyIdx="0">
<ns3:wrappedFeatureDescriptions>
<ns3:FeatureDescription description="freeFlowSpeed=53|driveType=0" themeId="PTV_SpeedPatterns"/>
</ns3:wrappedFeatureDescriptions>
</ns3:RouteListSegment>
<ns3:RouteListSegment utcOffset="60" countryCode="" iuCode="52" vNorm="0" nC="CITY_ROAD" accDist="2371" accTime="330" dirInfoIdx="-1" streetNameIdx="7" streetNoIdx="-1" nodeC="2" firstNodeIdx="42" polyC="2" firstPolyIdx="49">
<ns3:FeatureDescription description="freeFlowSpeed=44|driveType=0" themeId="PTV_SpeedPatterns"/>
<ns3:RouteListSegment utcOffset="60" countryCode="" iuCode="52" vNorm="0" nC="CITY_ROAD" accDist="2412" accTime="337" dirInfoIdx="-1" streetNameIdx="7" streetNoIdx="-1" nodeC="2" firstNodeIdx="43" polyC="2" firstPolyIdx="50">
<ns3:FeatureDescription description="freeFlowSpeed=48|driveType=0" themeId="PTV_SpeedPatterns"/>
</ns3:wrappedSegments>
<ns3:wrappedStations>
<ns3:WayPoint utcOffset="60" countryCode="" wayPointType="START" manoeuvreIdx="0" segmentIdx="0" nodeIdx="0" polyIdx="0" iuCode="52" accDist="0" accTime="0">
<ns3:locationCoord wkb="AAAAAAFAGEoCr70Ec0BIzfn+uHEP"/>
<ns3:matchCoord wkb="AAAAAAFAGEn7hEVJi0BIzfkSu26B"/>
</ns3:WayPoint>
<ns3:WayPoint [b]utcOffset="60" countryCode="" wayPointType="DEST" manoeuvreIdx="3" segmentIdx="40" nodeIdx="44" polyIdx="51" iuCode="52" accDist="2412" accTime="337">
<ns3:locationCoord wkb="AAAAAAFAGGfzkXTBekBIzQPWxHJg"/>
<ns3:matchCoord wkb="AAAAAAFAGGgARfsq50BIzQTlnmYY"/>
</ns3:WayPoint>
</ns3:wrappedStations>
Hope this Info is of interest
Cheers
Daniel
