xMapMatch 2 : Timestamp at track position
Posted: Fri Aug 04, 2023 7:56 am
recently I've been challenged by some partner who evaluates our map matching (2) / Developer API.
Thanks,
I know that we used a Timestamp even as a mandatory property of a track position. Can I get some feedback about what a user is supposed to expect from the xMapMatch2/DEV approach?I see one problem with your current API - you can only pass coordinates without time. It is a problem, because based on time there are different road restrictions, and also some road incidents could occur. For us, that functionalit is mainly for matching truck path to road, for visualization, but also for the reverse route, post factum, and also to calculate the toll for that route (which unfortunately needs to be done with 2 other requests in you API as I see concepts/recalculate-toll-and-emissions). So we have thousands of points, and based on that we calculate the toll. Rather a feature, not very common, but available, so If I would pass these thousands of points to routing...
Thanks,
