Sample Workflow DIMA calculation with HPR
Posted: Mon Jun 12, 2023 1:07 pm
From time to time new users encounter performance issues with the distance matrix calculation not knowing that PTV's routing experts developer an extremely fast mechanism which enables you to compute even large matrices within seconds. You may have heard of High-performance Routing
I therefore decided to provide a sequence of sample requests which could help to understand the necessary steps:
- You first need to pre-process the search graph with specific options such as
- a stored profile
- a scope
- some geographic restrictions (e.g. "allowedCountries")
- Each routing request (wether its a dima request or a simple a:b routing) which should use the created HPR via RoutingMode.HIGH_PERFORMANCE_ROUTING or RoutingMode.HIGH_PERFORMANCE_ROUTING_WITH_FALLBACK_CONVENTIONAL has to apply the same routing options that have been used during the creation of the graph. This also includes the geographic restrictions.
- A searchgraph for the Luxemburg area, applies the FeatureLayer PTV_TruckAttributes and uses a standard profile "trucktrailer". I also applied a simple scope called "samplerequest":
{ "label": "hello searchgraph", "scope": "samplerequest", "storedProfile": "trailertruck", "requestProfile": { "featureLayerProfile": { "themes": [ { "id": "PTV_TruckAttributes", "enabled": true } ] } }, "highPerformanceRoutingNetworkOptions": { "geographicRestrictions": { "allowedCountries": [ "LU" ] } } } - A Dima request:
{ "scope":"samplerequest", "$type": "CreateAndGetDistanceMatrixRequest", "distanceMatrixOptions":{ "routingType": "HIGH_PERFORMANCE_ROUTING", "geographicRestrictions": { "allowedCountries": [ "LU" ] } }, "storedProfile":"trailertruck", "requestProfile":{ "featureLayerProfile": { "themes": [ { "id": "PTV_TruckAttributes", "enabled": true } ] } }, "resultFields": { "distances": true, "travelTimes": true, "violated": true, "estimatedByDirectDistance": true }, "startLocations": [ { "$type": "OffRoadRouteLocation", "offRoadCoordinate": { "x": 6.22029, "y": 49.61513 } }, { "$type": "OffRoadRouteLocation", "offRoadCoordinate": { "x": 6.1029, "y": 49.6432 } } ] }
