Error "ExactTimeConsiderationAtArrival mode can not ..."
Posted: Wed Feb 08, 2023 1:10 pm
I have just got a xServer 2 CalculateRoute request from a "customer" that leads to the error:
My idea to solve the issue was to remove tourRestrictions from the request (or better to say not to add it) if ExactTimeConsiderationAtArrival is active. However I still got the same error response. It turned out that TOUR_EVENT caused the issue.
Question:
Can someone give me a pointer to the documentation that says that the combination of ExactTimeConsiderationAtArrival and tourRestrictions is not possible?
Dev Hint:
Unless it is another error I would appreciate if the error would contain TOUR_EVENT.
Requests snippets:
Request snippet 1: (with ExactTimeConsiderationAtArrival and tourRestrictions)
-> Response "ExactTimeConsiderationAtArrival mode can not be used if TourRestrictions are requested."
Request snippet 2: (with ExactTimeConsiderationAtArrival and w/o tourRestrictions, but TOUR_EVENT)
A message that includes "eventTypes TOUR_EVENT" is appreciated!
Request snippet 3: (with ExactTimeConsiderationAtArrival and w/o tourRestrictions and TOUR_EVENT)
-> Route will be calculated
The reason seems to be the combination of ExactTimeConsiderationAtArrival and tourRestrictions. From my POV I do not see a use case and see this as some kind of "see there is an error and I made no mistake" report to me.ExactTimeConsiderationAtArrival mode can not be used if TourRestrictions are requested.
Question:
Dev Hint:
Requests snippets:
"routeOptions": {
"timeConsideration": {
"$type": "ExactTimeConsiderationAtArrival",
"referenceTime": "2023-02-08T00:00:00"
"tourRestrictions": {
"configurableWorkingHours": {
"breakRule": {
"breakTime": 901.0,
"maximumDrivingTimeBetweenBreaks": 3601.0
"dailyRestRule": {
"dailyRestTime": 10801.0,
"maximumDrivingTimeBetweenDailyRests": 7201.0,
"dailyRestPosition": "ANYWHERE"
"resultFields": {
"eventTypes": [
"ROUTE_VIOLATION_EVENT", "TOUR_EVENT"
}Request snippet 2: (with ExactTimeConsiderationAtArrival and w/o tourRestrictions, but TOUR_EVENT)
"routeOptions": {
"resultFields": {
"eventTypes": [
}A message that includes "eventTypes TOUR_EVENT" is appreciated!
"routeOptions": {
"resultFields": {
"eventTypes": [
