How to print a map?
How to print a map?
a customer asked me how to print a map without displaying it in his user frontend.
At least for xServer.NET I found a method to create a print.
private void btnPrintToursResponse_Map_Click(object sender, EventArgs e)
      map.PrintMap(true, "My first Map");
But can I get a proper description from a more generic perspective? In the past I was able to create "Image from Stream" based on MemoryStreams and all business data such as icons, lines and areas have already been part of the "mapping request".
Nowadays everyone uses rest services to create interactive mapping frontends:
  • more than just a single image is requested
  • all business data is rendered on top through the mapping framework
But how to "render" the images in memory based approaches?
MyFirstMap.pdf
Printed via xServer.NET / C#. The regular "print to pdf" dialogue was triggered and produced this PDF.
(928.98 KiB) Downloaded 2806 times
Re: How to print a map?
Here's some sample code from my guru Oliver - it is based on xServer.NET and you can use it both for
  • PTV Developer - in this case ensure to provide a valid API key in line 37.
  • XMap2 (I went for a local url)
What is also important to be aware of:
:!: Oliver did choose a specific initialization sequence. Keep it!
:!: WIth this approach the application needs to be "[StaThread]" (whatever that means ;-))
Best regards and many thanks to Oliver.
using Ptv.XServer.Controls.Map;
using Ptv.XServer.Controls.Map.Layers.Shapes;
using Ptv.XServer.Controls.Map.Layers.Tiled;
using Ptv.XServer.Controls.Map.Symbols;
using Ptv.XServer.Controls.Map.TileProviders;
using Ptv.XServer.Controls.Map.Tools;
using System;
using System.IO;
using System.Windows;
using System.Windows.Media;
using System.Windows.Media.Imaging;
namespace GenerateMap
    class Program
        [STAThread]
        static void Main(string[] args)
            Point location = new Point(8.403951, 49.00921);
            var mapView = new MapView();
            mapView.Name = "Map";
            var p = GeoTransform.WGSToPtvMercator(location);
            mapView.SetXYZ(p.X, p.Y, 12, false);
            mapView.Printing = true;
            var sz = new Size(600, 400);
            var apiKey = Properties.Settings.Default.DeveloperApiKey;
            var basel = new TiledLayer("Road")
                TiledProvider = new RemoteTiledProvider
                    MinZoom = 0,
                    MaxZoom = 22,
                    RequestBuilderDelegate = (x, y, z) =>
                       $"https://api.myptv.com/rastermaps/v1/image-tiles/{z}/{x}/{y}?style=silkysand&apiKey={apiKey}",
                    //$"http://127.0.0.1:50000/services/rest/XMap/tile/{z}/{x}/{y}",
                IsBaseMapLayer = true,
            var pin = new Pin
                Color = Colors.Green,
                Width = 40,
                Height = 40,
            ShapeCanvas.SetAnchor(pin, LocationAnchor.RightBottom);
            ShapeCanvas.SetLocation(pin, location);
            var myLayer = new ShapeLayer("MyLayer");
            myLayer.Shapes.Add(pin);
            basel.AddToMapView(mapView);
            myLayer.AddToMapView(mapView);
            mapView.Measure(sz);
            mapView.Arrange(new Rect(new Point(0, 0), sz));
            mapView.UpdateLayout();
            var renderTargetBitmap = new RenderTargetBitmap((int)sz.Width, (int)sz.Height, 96d, 96d, PixelFormats.Default);
            renderTargetBitmap.Render(mapView);
            var jpegBitmapEncoder = new JpegBitmapEncoder();
            jpegBitmapEncoder.Frames.Add(BitmapFrame.Create(renderTargetBitmap));
            var ms = new MemoryStream();
            jpegBitmapEncoder.Save(ms);
            ms.Close();
            var bytes = ms.ToArray();
            var fileName = Path.GetTempPath() + "\\Img" + Guid.NewGuid() + ".jpg";
            File.WriteAllBytes(fileName, bytes);
            // open the image
            System.Diagnostics.Process.Start(fileName);
