I would like to ask if you can check our requests related with the xDima - > CreateDistanceMatrix, xTour - > planTour
It seems that sometimes ptv make no difference between the tours with the same address on many stops, or maybe something is wrong with our requests.
In the request we have the case with many orders in same addresses.
In this case the sequence from the response is: 3, 7, 1, 4, 8, 3. So, stop 1 is in the middle and stop 2 is missing completely. From our point of view it seems that this is not correct.
I would like to mention that this is related only with the xServer2.
Thanks
xTour2-Issue-Seq.Optimization-Many orders in same addresses
- Attachments
- xDima_createDistanceMatrix_Response.txt
- (3.1 KiB) Downloaded 457 times
- xTour_planTour_Request.txt
- (3.1 KiB) Downloaded 442 times
- xDima_createDistanceMatrix_Request.txt
- (1.47 KiB) Downloaded 419 times
Re: xTour2-Issue-Seq.Optimization-Many orders in same addres
Gruezi!
I'll take a look into this right now. Just to be safe: could you please provide your xTour response, too?
So far I see the following details:
The request mentions
- three PickupDelivery Orders:
1 (Bern) --> 3 (Chur)
3 (Chur) --> 4 (Willstätt)
7 (Bern) --> 8 (Chur) - All locations (1,2,3,4,7,8) are modelled as Depots.
- The vehicle is supposed to start at "1" (Bern) and ends at "2" (Chur).
- The stops of the single trip are: 3,7,1,4,8,3
- The sequence of the events is 1,3,7,1,4,8,3,2. So the final depot shows up at the end, but it does not appear in the stops sequence.
- Attachments
- planTours.response.js
- The planTours response (on xServer Internet)
- (12.03 KiB) Downloaded 432 times
Thanks.
This is the xTour response.
- Attachments
- xTour_planTour_Response.txt
- (5.24 KiB) Downloaded 446 times
Hello Beat,
our developer Christian took a look at your request and gathered the following details:
I'll get back to you 1:1 with an offer for a session together with Christian.You probably expect a solution based on the following sequence:
Pickup at 1 and 7, then Pickup at 3, then Delivery at 4 and Delivery 3 and 8.
But: If you arrive at 3 while you have the load from 1 then you have to unload over there because: you are not allowed to arrive at a site with it's load but without unloading it at the site.
On the other hand there's a rule that a trip MUST end at a depot if you unload over there.
This means that it requires at least two trips. As our algorithm prefers the reduction of trips over the travel time you get a result with a single trip.
Maybe you could improve the overall story by creating a new depot as a copy of 3?
