Meaning of "Solver problem: No valid solution found."
Posted: Tue Mar 22, 2022 9:05 am
HI there,
one of my contacts faced the following error message triggered by a planVisitRequest:
He asked me about the cause of this error and here is some info:Solver problem: No valid solution found.
- Cluster methods such as planVisits or planClusters try to identify a so-called "solution" which satisfies several threshold values, e.g. the imbalanceTolerance.
- Sometimes the algorithm is not able to find such a solution, either because the heuristic fails or because there is no such a solution.
- planClusters: Try to cluster 3 customers with equal activity over 2 clusters with a balance <20%: if one cluster get's two customers and the other one get's just one the balance is 100% (from 1 to 2).
- planVisits: Try to plan 6 visits of 60mins on 5 weekdays with a balance <5%: if one day get's two visits while all other days get 1 visit the balance is 100% (from 1 to 2)
