Performance MultipleTravelTimesConsideration
Posted: Tue Mar 01, 2022 11:12 am
Cheers,
these days a partner compared the calculation times of distance matrices within xDIma1 and xDima2. Here's some important feedback about this - related to MultipleTravelTimesConsideration:
- As the usecase is supposed to consider Break- and Restrules (aka WorkingHours) we needed to apply the MultipleTravelTimesConsideration.
- This limits us to a maximum planning horizon of 24hours.
- Try to apply HighPerformanceRouting if possible (on premise only)
- Try to simplify the calculation by applying one or even several of the following strategies:
- Reduce the scope of the DIMA dalculation: use geographic restrictions such as "reduction to continent" (allowedCountries={"ZZ_EUR"}), reduction to some countries (allowedCountries={"DE","AT","CH"} or even a small rectrangle (customBounds) - you can apply these in the Creation of the HPR and also in the calculation of the Dima.
Be aware that applying too many geographic filters could cause side effects, e.g. the intersection of RECT (area around Berlin) and COUNTRIES (DE,CH,AT) could lead to "waypoints not reachable" which has a negative impact onb performance AND output quality. - If your planning horizon's span is less than 24 hours (e.g. 06:00-18:00) you could also reduce the HPR/DIMA's MultipleTravelTimesConsideration interval to this.
