Resolving UK addresses with full post code in xLocate Intern
Oliver Meyer
Post by Oliver Meyer »
Hi Bernd and PTV team,
we're observing some weird behaviour of xLocate Internet when we try to geolocate addresses in the UK.
As you know, we provide a tour planning service ("maiTour") as an add-on to SAP Sales Cloud, and have to geolocate addresses that come out of our customers' systems. We're using the "findAddresses" operation from the XLocate 1.x API.
Now that we have a customer in UK, we observe some puzzling behaviour of the XLocate API:
1. Addresses that have a full postcode will be corrected by XLocate.findAddresses, but the result will only consist of the post code and the country code; the street, housenumber and city will be returned empty.
Example:
XLocate In:
  "addr": {
    "country": "GB",
    "postCode": "G53 6AG",
    "city": "SILVERBURN",
    "city2": "",
    "street": "BARRHEAD ROAD",
    "houseNumber": ""
XLocate out:
      "$type": "ResultAddress",
      "country": "GB",
      "state": "",
      "city": "",
      "city2": "",
      "street": "",
      "houseNumber": "",
      "adminRegion": "",
      "appendix": "",
      "countryCapital": "London",
      "totalScore": 100,
      "detailLevelDescription": "EXTPOSTCODE",
      "classificationDescription": "LOW",
      "coordinates": {
        "$type": "Point",
        "point": {
          "$type": "PlainPoint",
          "x": -482825.05073,
          "y": 7514600.4946
      "additionalFields": []
2. Addresses that have a correct street, housenumber and city, but a wrong or missing post code, will not be found, and replaced by something completely different.
Example:
XLocate in (note the wrong post code)
  "addr": {
    "country": "GB",
    "postCode": "G53 6QR",
    "city2": "",
    "houseNumber": ""
XLocate out (note: the totalScore of this address is so low that our service rejects it):
      "country": "GB",
      "state": "Scotland",
      "postCode": "EH26 9",
      "city": "Penicuik",
      "city2": "Silverburn",
      "street": "Biggar Road",
      "houseNumber": "",
      "adminRegion": "Penicuik",
      "appendix": "",
      "totalScore": 41,
      "detailLevelDescription": "STREET",
      "coordinates": {
        "$type": "Point",
        "point": {
          "x": -363862.04651,
          "y": 7516122.7815
3. Addresses that have a correct street, housenumber and city, and only the first part of the post code (the "outward code"; only area and district), will usually be found correctly, and street, housenumber (if present) and city will be correct also in the returned result.
Example:
XLocate in:
  "addr": {
    "country": "GB",
    "postCode": "G53",
    "city2": "",
    "houseNumber": ""
XLocate out:
      "country": "GB",
      "postCode": "G53 6",
      "city": "Glasgow",
      "city2": "",
      "street": "Barrhead Road",
      "houseNumber": "",
      "adminRegion": "Glasgow",
      "appendix": "",
      "totalScore": 66,
      "detailLevelDescription": "HNRSECTION",
      "classificationDescription": "MEDIUM",
      "coordinates": {
        "$type": "Point",
        "point": {
          "x": -482042.23845,
          "y": 7514857.8172
The ideal response would be a mix of case 1 and case 3, i.e. when the post code is correct, not only the coordinates should be returned correctly, but also the address.
Is there something about this we can influence by setting specific parameters?
Setting POSTCODE_AGGREGATE didn't change anything about the result.
Or do we have to adapt our service to the values returned in the result, like detailLevelDescription?
Kind Regards
Oliver Meyer
nagarro ES GmbH
Westerbachstraße 32
61476 Kronberg im Taunus
Re: Resolving UK addresses with full post code in xLocate In
Hi Oliver,
did you already check this article?
https://xserver.ptvgroup.com/forum/view ... CODE#p2426
Roughly spoken there's an additional table with (more than a million!) UK 7digit postcodes + (x,y). This table does not contain any citynames, districts or streets.
If you enter a zipcode with 6 or 7 digits (with or without other fields such as city or streetname) we check this table and if there's a match we return "the extended postcode", (x,y) and the level "EXTPOSTCODE".
WIthout a match we perform the regular geocoding based on the maps own dataset.
What I'll do next:
- I'll ask Jochen to comment on this, too
- I'll try to find out whether there's a API parameter that disables the 2 steps and immediately enforces the step 2 (search on map data).
bocajo
Post by bocajo »
Hi together
Bernd explained the behavior of UK post code search in xLocate 1 very good. What I can say is that there is no API parameter to disable the 2 steps.
Maybe you can check xLocate 2? Here we integrated the 6/7 digits UK post codes into the search index and the response returns postal code, city, street and housenumber there aren't to search steps and no additional postal code file.
Jochen Anderer
Manager Engineer
PTV GROUP GERMANY
Oliver Meyer
Hi Bernd and Jochen,
thanks for clearing this up.
I think there's an easy workaround for us:
If we find the EXTPOSTCODE level in the response from xLocate, we just don't copy the street, house number and city fields from the response, but instead copy them from the original input data. That way, we leave it to the responsibility of our customers to maintain their data correctly so the actual address matches the postal code.
Is the presence of the EXTPOSTCODE level a reliable indicator for the coordinates being correct, as per the UK post code table? Is this level also used for other countries, and if so, does it have the same meaning?
Cheers
Oliver
Here's some more info about the extended postcode.
It's main purpose - at least from my perspective - is to gather a ~100m coordinate (precise enough for a tender, not precise enough for the postman) if the input zipcode is 100% correct. No fuzzy search, no typos...
Look at https://xserver.ptvgroup.com/forum/down ... &mode=view - there you can see the same approach in the US. Each dot is a single code. Coverage is enough for the tender usecase.
