Using curl for communications
Posted: Thu Apr 15, 2021 9:49 am
We are trying to get data from PTV using curl from our Linux server.
The request itself we test at the raw request runner and put in a file "/..../PTV_TEST4.TXT"
If we test with the command:
curl -X GET -H 'Authorization: username xtok' -H 'Authorization: password *token*' -H 'Content-Type: application/soap+xml;charset=utf-8' --data-binary @ '/........../PTV_TEST4.TXT' 'https://xserver2-europe-eu-test.cloud.p ... /ws/XRoute'
The respons is: curl: (3) <url> malformed
So there must be a small syntax problem in my command.
Can someone help me with the correct command to use with curl?
Thanks in Advance.
Greetings
Koos
Thanks in Advance.
Greetings
Koos
