Geocoding in Map&Guide differs from xLocate 2
Posted: Mon Mar 22, 2021 8:56 am
recently I've been approached by a customer with the following topic:
The geocoding output in Map&Guide Internet (MGI) differs from the xLocate 2 output: The main reason for the difference in the behaviour of the two applications is the engine used in the background:
Furthermore the new engine does not provide the same number of confusing parameters as xLocate1 did (caused too many discussions, was too difficult to explain). XLocate 2 development simply reduces the number of parameters to a meaningful minimum.
From our perspective neither xLocate1 nor xLocate2 is wrong - they are just different.
Update 10.1.2022: a sample request from MGI - you might want to play with CITY_RETURNALLCITY2 to get a more detailed response list in case of surficial input:
- MGI uses PTV xLocate Server (22.3.2021)
- XServer2 uses PTV xLocate Server2
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<findAddressByText xmlns="http://types.xlocate.xserver.ptvag.com">
<String_1>Mitteregg</String_1>
<String_2>AT</String_2>
<ArrayOfSearchOptionBase_3>
<SearchOptionBase xsi:type="SearchOption" value="False" param="STREET_RETURNALLHNR" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="100" param="MAX_RESULT" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="DEU" param="RESULT_LANGUAGE" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="6" param="COUNTRY_CODETYPE" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="true" param="SEARCH_BINARY" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="true" param="SEARCH_FUZZY" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="," param="SINGLE_FIELD_SEPARATORS" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="SearchOption" value="false" param="CITY_RETURNALLCITY2" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="NamedSearchOption" value="false" param="FREQUENCYFILTERING" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="NamedSearchOption" value="false" param="EXTENSIVESEARCH" xmlns="http://xlocate.xserver.ptvag.com" />
</ArrayOfSearchOptionBase_3>
<ArrayOfSortOption_4 xsi:nil="true" />
<ArrayOfResultField_5>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">POPULATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">ADDRESS_CLASSIFICATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">POSTCODE_CLASSIFICATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">TOWN_CLASSIFICATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">STREET_CLASSIFICATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">HOUSENR_CLASSIFICATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">LEVEL</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">DETAILLEVEL</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">ARTIFICIALTOWNCHARACTERIZATION</ResultField>
<ResultField xmlns="http://xlocate.xserver.ptvag.com">STATE</ResultField>
</ArrayOfResultField_5>
<CallerContext_6 log2="">
<CallerContextProperty key="CoordFormat" value="OG_GEODECIMAL" />
<CallerContextProperty key="ResponseGeometry" value="PLAIN" />
<CallerContextProperty key="ContextKey" value="" />
</wrappedProperties>
</CallerContext_6>
</findAddressByText>
</soap:Body>
</soap:Envelope>
