AjaxMaps debug Popup
Posted: Tue Mar 09, 2021 6:02 pm
by i.kobeissy
We are using ajaxMaps in our application, lately with Chrome browser we are getting a debug popup that popup up when loading a screen with an embedded ajaxMaps. It's not systematic, we don't have a pattern for reproducing the case. so my question is, is it possible to prohibit the showing of this popup ?
Re: AjaxMaps debug Popup
Posted: Tue Mar 09, 2021 6:07 pm
Hello Ibrahim,
I forwarded this to the developer of the AJAX control - I hope he responds soon.
If not: get back to me 1:1!
Posted: Tue Mar 09, 2021 9:15 pm
by AndreasJunghans
Hello Ibrahim,
what's the contents of this popup?
Andreas
Posted: Wed Mar 10, 2021 7:30 am
by i.kobeissy
Hello Andreas,
The popup contains the following lines
000750 DEBUG: qxp.core.Init[3]: qooxdoo 0.6.2-pre (r4314)
000771 DEBUG: qxp.core.Init[3]: loaded 40 classes
000773 DEBUG: qxp.core.Init[3]: client: webkit-537.36/win/en
and here's a screenshot of it
- debugPopup
Posted: Wed Mar 10, 2021 9:11 am
by AndreasJunghans
This looks like a symptom of another problem. Usually, this is what happens:
1) Some basic infrastructure is set up, including logging (default log level is "debug").
2) The actual map code is loaded, which sets the log level higher.
3) In the onload event, some debug logging is performed (what you see in the popup), but it should be suppressed because of step 2.
So I think the actual problem is some error in step 2. Could you take a look at the JavaScript console to see which errors are printed there when the popup appears?
Posted: Wed Mar 10, 2021 6:10 pm
by i.kobeissy
Hello Andreas
thanks for your answer, in fact you are right I found that we have errors in the console when the popup is shows
Uncaught TypeError: vRequest is null
Uncaught ReferenceError: qxp is not defined
so I will try to solve this issue inside our application
Thank you
