xServer 2.22 released
Posted: Fri Mar 05, 2021 1:58 pm
here's another release of our xServer v2.22. My personal highlight is the calculation of the reacheable area along a route (usecase : geofence or corridor search)
Release Webinars:
German: 23.3.2021 / 16:00 CET Recording
English: 24.3.2021 / 16:00 CET Recording
Release Webinars:
Dear xServer Stakeholders,
the PTV xServer 2.22 is released! And these are the highlights:
o xData: Retrieve additional segment information via segment IDs, e.g. from routing or matching results
o xData: Apply annotations and absolute speeds with custom Feature Layers (Integration sample)
o xLocate: Use as allowed countries also country subdivisions like US states
o xDima/xRoute: Penalize turns on intersections, e.g. to prefer turns on passenger side (Technical Concept)
o xRoute: Calculate a corridor around a route (Showcase)
o xTour: Use multiple driver break intervals with the same duration
o xTour: Use multiple driver operating intervals also in combination with break intervals
Please note that due to changed default values in the routing profile, it is necessary to recalculate your high-performance routing networks. (We improved the internal handling of violations and restricted areas which required us to change some internal engine defaults. This is relevant for routing and in some cases the search graphs do not match the engine any more. We therefore recommend to update your search graphs if you apply the server update to v2.22+)
Moreover the default for the available two toll data formats switched from basic to detailed.
The on-premise solution can be found here:
o Developer Zone (login required)
The cloud solution PTV xServer internet will be updated according to this plan:
o 15.03.21: Productive system hosted in Australia
o 29.03.21: Productive system hosted in Europa
o 30.03.21: Productive system hosted in US
Regards, your transportation services teams
