HPR Troubleshoot:how to trace conflicting routing options?
Posted: Fri Jan 08, 2021 12:43 pm
sometimes you may encounter the fallback from HPR to CONVENTIONAL in a routing or dima request of xServer2. Though you are getting told that the fallback is applied you might want to know in depth why there's no search graph matching your requested profile.
The troubleshooting paragraph says:
Of course this is only a valid approach on premise
Add a specific logger section in the logging-module.xml to trace this in xRoute:
For xDima the section looks like this:
Here's some sample trace from a logfile:
Another potential source of the mismatch is the scope: if you create your own search graphs through xData you need to ensure that TENANT and SCOPE are matching, too (not a topic for global graophs)
Last but not least the allowedCountries and prohibitedCountries in a Dima request have to match, too.
Thanks to Max for the hint!
Here's a hint that is currently missing in the documentation and we will add it later. For the impatient ones:Another possibility is to enable the trace logs of the corresponding service. Then, for each high-performance routing network the parameters that are different to the routing relevant parameters of the request are logged.
<Logger name="com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools"
level="trace" additivity="false">
<AppenderRef ref="File"/>
</Logger>Code: Select all
<Logger name="com.ptvgroup.xserver.xdima.router.ContractionHierarchiesTools"
</Logger>2021-01-07 11:11:01,938;DEBUG;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;No high-performance routing data available in the hpr folder of the map for current profile settings.
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;--> "/opt/maps/PTV_World_City_Map_Premium_2021_1H/hpr/46fc4498-3dc1-48c3-94e1-ca17e00a13d6"
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs TIMECONSIDERATION_MODE: SNAPSHOT != NONE
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs allowedCountries: 1110111111100111111111111111111111111110010000000110000100011111011111000000000000000000000000000000000000010000000100110000000100010000000000000000000000000011000101000000000000100001010000000000000100000000000000000000000000001110110001000010001000010000100001000100000000000000000000000000000000000000000000000000000000000000000000000000000000000 != 1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs vehicleProfile/@numberOfTrailers: 1 != 0
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs vehicleProfile/axle/@axleLoad: 10000 != 11500
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs vehicleProfile/dimensions/@length: 1875 != 1650
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs vehicleProfile/weight/@emptyWeight: 14500 != 15000
2021-01-07 11:11:01,940;TRACE;com.ptvgroup.xserver.xroute.router.ContractionHierarchiesTools.ChDataAdministration;differs vehicleProfile/weight/@loadWeight: 25500 != 25000
