Important info: Detailed toll available on PROD soon!
Posted: Wed Dec 02, 2020 10:58 am
I know that many parties are waiting for the following information provided by Isabel on the DEVBLOG:
- From Dec 16th, 2020 the HEAD version of the Route Request will return DETAILED TOLL level by default (in other words: you do not ned to access the EXPERIMENTAL TollOption.useDetailedToll
- You will be able to request the TollResultFields for Sections and Systems (today 2.12.2020 this requires EXPERIMENTAL or causes an error)
- Furthermore the v2.21 (head) will also return the toll per country as part of the TollSummary
If you have questions: let me know!
If you want to play with the showcase - just do it!
That means:We would like to inform you that we plan to perform maintenance on the PTV xServer 2 cluster with PTV World City Map [Here] on December 7th, 2020 and December 16th 2020.
The following tasks will be completed in the scope of this maintenance:
December 7th, 2020: PTV xServer update to PTV xServer 2.21
December 16th 2020: Change of configuration for toll calculation
We will change the default toll calculation to “Detailed Toll”. That means that you get the detailed toll automatically, when requesting toll in the route calculation. We can do this step, because the coverage of detailed toll now has reached the level of the basic toll. There is only one exception: If you like to calculate toll in Australia, you have to set the parameter useDetailedToll = false in the request to get still the basic toll for Australia. That is necessary until Australia will be updated with the detailed toll as well.
The test system was updated already, please test your application during the test phase and report any faults immediately.
