Exception: "Maximum attribute size limit (65536) exceeded"
Posted: Thu Mar 19, 2015 6:03 pm
Hello out there,
today a colleague mentioned the following generic issue: It occurs when you try to use a property (string, wkb, ...) that exceeds the length 65536 which is the implicit default value.
The workaround for this is quite simple:
Add the following key into the /conf/wrapper.conf and restart the service:
Thanks to Joost Claessen
for the hint,
I reproduced the error and the complete message looks like this:I ran into an issue with a customer where the 1.20 version of xMap can no longer handle big WKB string. You will get a error that the "Maximum attribute size limit (65536) exceeded".
<soap:Body>
<soap:Fault>
<faultcode>soap:Client</faultcode>
<faultstring>Unmarshalling Error: Maximum attribute size limit (65536) exceeded </faultstring>
</soap:Fault>
</soap:Body>
</soap:Envelope>The workaround for this is quite simple:
- wrapper.java.additional.21=-Dorg.apache.cxf.stax.maxAttributeSize=99999999
