Currency Romanian leu - Romania code ROL
Posted: Wed Jun 10, 2020 2:07 pm
by nirengp
We encountered the problem of wrong ISO Code 3 for Romanian leu - Romania currency is returned from PTV xRouteServer. Actually ISO Code 3 should be RON. However, in CountryInfo.Currency code we are getting it as ROL.
So how can this be corrected?
Thank you
Re: Currency Romanian leu - Romania code ROL
Posted: Wed Jun 10, 2020 3:44 pm
Hello Niren,
I created a bugtracking task (MPXSRV-4404). Looks like we have an issue here ;-)
Now we need a feedback from DEV.
Posted: Fri Jun 12, 2020 4:23 am
by nirengp
Any timelines by which we can expect response from DEV.
Thanks
Posted: Fri Jun 12, 2020 7:19 am
at least I have a feedback from a consulting colleague (Thanks Joost!):
The countryInfo.currency is deprecated. It is an enumeration so we cannot change this without breaking backwards compatibility. The customer should use currencyISOCode, which is returned if you set countryInfoOptions.currencyDescription=true in your input. The currencyISOCode is correct.
sample response...
sample response...
Please consider to switch to the recommended property,
Posted: Fri Jun 12, 2020 10:42 am
by nirengp
I tried setting countryInfoOptions.currencyDescription=true while calling calculateExtendedRoute().
However, getting currencyISOCode as null in response.
Is their any sample which I can check to see what am I missing for this?
Thanks
Posted: Fri Jun 12, 2020 11:01 am
here's a sample JSON... Maybe a bit oversized (Budapest to Bukarest)
  "waypoints": [
      "$type": "TourPointDesc",
      "linkType": "AUTO_LINKING",
      "fuzzyRadius": 0,
      "coords": [
          "$type": "Point",
          "point": {
            "$type": "PlainPoint",
            "x": 2902433.3262,
            "y": 5526905.5204
      "fuzzyRadius": 0,
      "coords": [
          "$type": "Point",
          "point": {
            "x": 2117212.5605,
            "y": 6017026.8256
  "options": [
      "parameter": "REQUEST_VERSION",
      "value": "1.6"
      "parameter": "COUNTRY_ENCODING",
      "value": "ISO2"
      "parameter": "ROUTE_LANGUAGE",
      "value": "EN"
      "parameter": "DISTANCE_MEASURE",
      "value": "KM"
  "exceptionPaths": null,
  "details": {
    "manoeuvres": false,
    "texts": false,
    "nodes": false,
    "binaryPathDesc": false,
    "polygon": false,
    "polygonElevations": false,
    "detailLevel": "STANDARD",
    "dynamicInfo": false,
    "segments": false,
    "segmentAttributes": false,
    "segmentAttributePiggyback": false,
    "manoeuvreAttributes": false,
    "brunnelManoeuvres": false,
    "urbanManoeuvres": false,
    "manoeuvreGroups": false,
    "tollManoeuvres": false,
    "boundingRectanglesC": 0,
    "boundingRectanglesOffset": 1000,
    "totalRectangle": false,
    "extSegments": false,
    "speedLimits": false,
    "featureDescriptions": false,
    "utcOffsets": true
  "countryInfoOptions": {
    "$type": "CountryInfoVehicleOptions",
    "detailedTollCosts": false,
    "allEuro": false,
    "calculatePartTollCosts": true,
    "namedToll": true,
    "tollTotals": true,
    "currencyDescription": true,
    "waypointIndexInTollCostInfo": true
  "callerContext": {
    "properties": [
        "key": "Profile",
        "value": "truckfast"
        "key": "CoordFormat",
        "value": "PTV_MERCATOR"
Here's also the response:
  "$type": "ExtendedRoute",
  "route": {
    "info": {
      "distance": 831805,
      "time": 44433,
      "cost": 540349
    "stations": [
        "$type": "WayPoint",
        "accTime": 0,
        "accDist": 0,
        "iuCode": 40,
        "polyIdx": 0,
        "nodeIdx": 0,
        "segmentIdx": 0,
        "manoeuvreIdx": 0,
        "locationCoord": {
          "$type": "Point",
          "point": {
            "x": 2902428.6809,
            "y": 5526904.9147
        "matchCoord": {
          "$type": "Point",
          "point": {
            "x": 2902433.6999,
            "y": 5526905.3336
        "wayPointType": "START",
        "countryCode": "RO",
        "utcOffset": 180
        "accTime": 44433,
        "accDist": 831804,
        "iuCode": 36,
        "polyIdx": 4864,
        "nodeIdx": 3536,
        "segmentIdx": 2302,
        "manoeuvreIdx": 29,
        "locationCoord": {
          "$type": "Point",
          "point": {
            "x": 2117208.2621,
            "y": 6017026.2036
        "matchCoord": {
          "$type": "Point",
          "point": {
            "x": 2117212.7982,
            "y": 6017026.1125
        "wayPointType": "DEST",
        "countryCode": "HU",
        "utcOffset": 120
  "countryInfos": [
      "iuCode": 40,
      "partRouteInfo": {
        "distance": 613653,
        "time": 33152,
        "cost": 0
      "currency": "ROL",
      "currencyName": "Romanian Leu",
      "currencyISOCode": "RON",
      "additionalInfo": "",
      "tollName": "",
      "tollTotals": {
        "distance": 0,
        "cost": 0
      "perNCRouteInfo": [
          "distance": 453470,
          "time": 20659,
          "cost": 0
          "distance": 148420,
          "time": 11227,
          "cost": 0
          "distance": 10635,
          "time": 1063,
          "cost": 0
          "distance": 1128,
          "time": 203,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
      "perTypeTollDistance": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0
      "perTypeTollPrice": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0
      "iuCode": 36,
      "partRouteInfo": {
        "distance": 218151,
        "time": 11281,
        "cost": 204202
      "currency": "HUF",
      "currencyName": "Hungarian Forint",
      "currencyISOCode": "HUF",
      "tollName": "",
      "tollTotals": {
        "distance": 204360,
        "cost": 1062783
      "perNCRouteInfo": [
          "distance": 204935,
          "time": 9687,
          "cost": 204202
          "distance": 0,
          "time": 0,
          "cost": 0
          "distance": 8238,
          "time": 789,
          "cost": 0
          "distance": 4301,
          "time": 642,
          "cost": 0
          "distance": 677,
          "time": 163,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
          "distance": 0,
          "time": 0,
          "cost": 0
        0,
        204360,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        204360,
        0
        0,
        1062783,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        1062783,
        0
  "partTollCosts": [
      "distance": 204360,
      "costs": [
          "cost": 1062783,
          "currency": "HUF",
          "iuCode": 36,
          "type": "NATIONALTOLL"
Posted: Sat Jun 13, 2020 4:41 am
by nirengp
I tried setting coutryInfoOptions as per the sample you provided.
Still the currencyISOCode in response is null. Not sure why!!.
Is their any configuration required in PTV xServer. We are using xServer version 1.24.
I will give it one more try, and will get back to you.
Thanks
Posted: Tue Jun 16, 2020 6:24 am
by nirengp
It worked. Thanks for the help.
