routing: how to activate FreeFlowSpeed?
Posted: Fri Mar 06, 2015 2:43 pm
these days I was asked by several customers how to enable the FreeFlowSpeed parameter within routing. As this question has affects xRoute, xDima, xTour (and any other routing based server module) I decided to place it in the generic forum:
I'd like to go a little bit more into details:
Do not hesitate to get in touch with us in case of questions,
- FreeFlowSpeed values are an alternative to the speed mechanism provided by PTVs traditional speedclass/networkclass approach (SC/NC): our data providers deliver a specific speed value called FreeFlowSpeed. It's usage disables (replaces) the SP/NC.
- You need access to the corresponding feature layer (proper license keys (e.g. xroute.featureLayerThemes), additional data)
- WIthin the request or profile you have to use the following parameters
- @\Routing\Course\DynamicRouting\useFreeFlowSpeed=true
- @\FeatureLayer\GlobalSettings\enableTimeDependency=false
- @\FeatureLayer\Themes\Theme\id="PTV_SpeedPatterns" enabled="true"
<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <Profile> <Routing majorVersion="2" minorVersion="0"> <Course> <AdditionalDataRules enabled="true"/> <DynamicRouting limitDynamicSpeedToStaticSpeed="false" useFreeFlowSpeed="true"/> </Course> </Routing> <FeatureLayer majorVersion="1" minorVersion="0"> <GlobalSettings enableTimeDependency="false"/> <Themes> <Theme id="PTV_SpeedPatterns" enabled="true"/> </Themes> </FeatureLayer> </Profile>
