Dima C# Sample
Posted: Thu May 14, 2020 8:47 am
by HarryM
I'm new to xServer and seek for a working C# sample code which shows who to deal with xDima.
The sample on https://xserver2-europe-eu-test.cloud.p ... ntents.htm doesn't work.
I.e. DistanceMatrixContentsOptions, GetDistanceMatrixByLocationsRequest are not found,
createDistanceMatrixResponse distanceMatrixResponse = xdima.createDistanceMatrix(createDistanceMatrixRequest); drops a NullReference error.
Pleae help!
Harry
Re: Dima C# Sample
Posted: Fri May 15, 2020 6:10 am
by HarryM
after struggeling around, I found an other sample using xServer, but the DistanceMatrixRespone.Contents are always NULL. How I understand there should be the response matrix. What's wrong?
Please help!
Harry
using System;
using System.Threading.Tasks;
using System.Net.Http;
using System.Net;
using XServerClient;
using System.Globalization;
using XServerClient.Models;
using System.Diagnostics;
using System.Collections;
using System.Collections.Generic;
namespace XServerJson
    class Program
        static void Main()
            ExecAsync().Wait();
            Console.ReadKey();
        static async Task ExecAsync()
            // initialize client for xserver-internet
            var xServer = new XServer(
            new Uri("https://xserver2-europe-eu-test.cloud.ptvgroup.com"), new HttpClientHandler
                Credentials = new NetworkCredential
                    Password = "<TOKEN>",
                    UserName = "xtok"
            try
                CreateDistanceMatrixRequest createDistanceMatrixRequest = constructCreateDistanceMatrixRequest();
                var job = await xServer.StartCreateDistanceMatrixAsync(createDistanceMatrixRequest);
                var id = job.Id;
                while (job.Status == JobStatus.QUEUING || job.Status == JobStatus.RUNNING)
                    await Task.Delay(1000);
                    job = await xServer.WatchJobAsync(new WatchRequest { Id = id });
                if (job.Status == JobStatus.SUCCEEDED)
                    var result = await xServer.FetchDistanceMatrixResponseAsync(new JobRequest { Id = id });
                    DistanceMatrixContents con = ((DistanceMatrixResponse)result).Contents;
                    if (con == null)
                        Console.WriteLine("NULL");
                    else
                        Console.WriteLine($@"{con}");
                else
                    Console.WriteLine($@"Failed with status: {job.Status}");
                await xServer.DeleteJobAsync(new JobRequest { Id = job.Id });
            catch (XServerErrorException ex)
                Console.WriteLine($"Request failed with error: {ex.Response.Content}");
            finally
                xServer.Dispose();
        private static CreateDistanceMatrixRequest constructCreateDistanceMatrixRequest()
            List<RouteLocation> startLocations = new List<RouteLocation>();
            List<RouteLocation> destLocations = new List<RouteLocation>();
            startLocations.Add(createOffRoadCoordinate(10.7134, 49.7519));
            startLocations.Add(createOffRoadCoordinate(11.0167, 49.8));
            startLocations.Add(createOffRoadCoordinate(10.8886, 50.015));
            startLocations.Add(createOffRoadCoordinate(11.9305, 51.0801));
            destLocations.Add(createOffRoadCoordinate(11.58198, 48.135125));
            CreateDistanceMatrixRequest createDistanceMatrixRequest = new CreateDistanceMatrixRequest
                StartLocations = startLocations.ToArray(),
                DestinationLocations = destLocations.ToArray(),
                StoredProfile = "truck40t"
            return createDistanceMatrixRequest;
        public static Coordinate createCoordinate(double x, double y)
            Coordinate coordinate = new Coordinate
                X = x,
                Y = y
            return coordinate;
        public static RouteLocation createOffRoadCoordinate(double x, double y)
            OffRoadRouteLocation offRoadRouteLocation = new OffRoadRouteLocation
                OffRoadCoordinate = createCoordinate(x, y),
            return offRoadRouteLocation;
        public static RouteLocation createOnRoadCoordinate(double x, double y)
            OnRoadRouteLocation onRoadRouteLocation = new OnRoadRouteLocation
            return onRoadRouteLocation;
Re: Dima C# Sample
Posted: Fri May 15, 2020 6:55 am
by Joost
You are using CreateDistanceMatrixRequest . This is designed for calculating a dima and leave it on the server so other xServer (like xTour and xCluster) can use it. If you want to get the result you have to use the derived type CreateAndGetDistanceMatrixRequest as request.
Keep in mind that CreateAndGetDistanceMatrixRequest does not leave the dima on the server. If you need the dima to persist but still want the content you can extend your current code with a getDistanceMatrix folow-up.
Re: Dima C# Sample
Posted: Fri May 15, 2020 7:59 am
by HarryM
Thank you!
Now it works ...
