Actually in your xRoute request you are setting multiple routing options that affect the Effective routing. The effective profile is the "de facto"" profile that is applied. It is created using settings from all applicable profiles in the following order, where each step overwrites values of the previous one:
1 default value specified in the profile XML schema
2 server profile referred to as parent of a server profile
3 server profile referred to in the request callerContext
4 profile snippet in the request callerContext
5 API parameters in the request
Documentation link:
https://xserver.ptvgroup.com/fileadmin/ ... ofiles.htm
So have a look at the settings:
<ns7:RoutingOption parameter="OPTIMIZATION" value="90"/>
This maps to Routing / Course / @distanceTimeWeighting. You do not set this in the dimatruck so it defaults to 80.
<ns7:RoutingOption parameter="LOW_EMISSION_ZONE_TYPE" value="1"/>
This maps to Routing / Vehicle / Physical / Drive / Emissions / @lowEmissionZoneType . You do not set this in the dimatruck so it defaults to GREEN which is the same as using 1 in your routing option.
<ns7:RoutingOption parameter="AVOID_TOLLROADS" value="2501"/>
Routing / Course / BasicDataRules / Toll / @tollMalus . You have this set to 2501 in the dimatruck profile.
<ns7:RoutingOption parameter="AVOID_VIGNETTEROADS" value="2501"/>
Routing / Course / BasicDataRules / Toll / @vignetteMalus. You have this set to 0 in the dimatruck profile.
<ns7:RoutingOption parameter="AVOID_FERRIES" value="2500"/>
Routing / Course / BasicDataRules / CombinedTransport / @ferryMalus. You have this set to 100 in the dimatruck profile.
<ns7:RoutingOption parameter="AVOID_RESIDENTS_ONLY" value="2500"/>
Routing / Course / BasicDataRules / SpecialAreas / @residentialMalus . You have set this to 2500 in the dimatruck profile
<ns7:RoutingOption parameter="AVOID_RAMPS" value="10"/>
Routing / Course / BasicDataRules / Network / @rampMalus. You have this set to 10 in the dimatruck profile.
Other options are set to false and thus have no effect or do not effect the routing at all (ROUTE_LANGUAGE).
