XS1 to XS2: speed profiles and maximumSpeed
Posted: Wed Jan 29, 2020 12:35 pm
HI there,
let me draw your attention to the following change between xRoute 1 and xRoute 2: these days a player wanted to compare results of xRoute1.calculateExtendedRoute with xRoute2.calculateRoute. In both cases the speed values mentioned in his requests looked equal but the driving periods of the results differed.
He specified 2x8 speed values as described in https://xserver2-europe-eu-test.cloud.p ... asses.html We identified the maximumSpeed parameter as the cause for the gap:
https://xserver2-europe-eu-test.cloud.p ... ile.Speeds
Though the maximumSpeed is labeled optional with a default of 255 km/h the xServer2 result never drove faster than 80km/h. Now this is what you should be aware of:
- the xroute1 default profile does not contain a maxSpeed value, therefore the documented default value of 255 applies. As most routings deal with speed vectors below 255 we wouldn't have to cut speeds.
- the xRoute2 default profile explicitly mentions a maximumSpeed of 80km/h which means that the default value of the documentation is never reached. Instead of this the speed values will be cut to 80km/h if you do not explicitly override the maximumSpeed with the request. I forwarded this experience to DEV and recommended a clear comment in the API doc
