Could not read configuration file logging.properties
Prakash
Post by Prakash »
Hello guys,
I have set up two instances of xTour & xCluster 1.26, after the setup getting below errors:
ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;raw msg from m0008 - log4cxx: Could not read configuration file [..\xCluster-NorthAmerica\webapps\xcluster\WEB-INF\lib\logging.properties]
ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;raw msg from m0008 - log4cxx: Could not read configuration file [..\xCluster-here\webapps\xcluster\WEB-INF\lib\logging.properties].
ERROR;com.ptvgroup.xserver.framework.ModuleInstanceProcessWrapper;raw msg from m0012 - log4cxx: Could not read configuration file [..\xTour-HERE\webapps\xtour\WEB-INF\lib\logging.properties].
Could you please let me know how can I figure out the reason of this issue.
Thanks in advance,
Prakash Kumar
Developer
Webdirekt India Pvt. Ltd.
Re: Could not read configuration file logging.properties
Hello Prakash,
Please create a regular support ticket. Sound like a topic that requires 1:1 analysis.
