xServer2 - CalculateRoute causes internal exception
Posted: Thu Nov 21, 2019 3:20 pm
Hey!
Calculating a route from Munich to Hamburg can cause an internal exception.
After changing the property "distanceTimeWeighting" from >=32 to 31 it's working.
The module log says because of maximum costs..?
Thank you.
xServer2 Version: 2.15.0
Map Version: 2020_1H
Request:
Respone:
Module-Log:
Thank you.
Request:
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">
<s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<calculateRoute xmlns="http://xroute.xserver.ptvgroup.com">
<request xmlns="" coordinateFormat="EPSG:76131">
<requestProfile mapLanguage="de" userLanguage="de">
<vehicleProfile driveType="MOTOR_VEHICLE" numberOfTrailers="0">
<engine emissionStandardEU="EURO_6"/>
<weight totalPermittedWeight="36000"/>
<dimensions height="400" length="1800" width="250"/>
<axle axleLoad="3500" numberOfAxles="5"/>
<legalCondition isDelivery="true"/>
<load loadType="GOODS"/>
<speeds>
<speedRangesByNetworkClass>
<maximumSpeeds>90</maximumSpeeds>
<maximumSpeeds>70</maximumSpeeds>
<maximumSpeeds>60</maximumSpeeds>
<maximumSpeeds>40</maximumSpeeds>
<maximumSpeeds>30</maximumSpeeds>
<maximumSpeeds>20</maximumSpeeds>
<maximumSpeeds>0</maximumSpeeds>
<maximumSpeeds>2</maximumSpeeds>
<minimumSpeeds>50</minimumSpeeds>
<minimumSpeeds>40</minimumSpeeds>
<minimumSpeeds>20</minimumSpeeds>
<minimumSpeeds>10</minimumSpeeds>
<minimumSpeeds>5</minimumSpeeds>
<minimumSpeeds>0</minimumSpeeds>
<minimumSpeeds>2</minimumSpeeds>
</speedRangesByNetworkClass>
</speeds>
</vehicleProfile>
<featureLayerProfile>
<themes id="PTV_TruckAttributes" enabled="true"/>
</featureLayerProfile>
<routingProfile>
<course distanceTimeWeighting="32">
<network rampPenalty="0">
<penaltiesByNetworkClass>
<penalties>0</penalties>
<penalties>15</penalties>
<penalties>50</penalties>
<penalties>100</penalties>
</penaltiesByNetworkClass>
</network>
<toll tollPenalty="0"/>
<specialAreas residentsOnlyPenalty="0" urbanPenalty="0"/>
<combinedTransport boatPenalty="0"/>
<maneuver considerTurningBans="true"/>
</course>
</routingProfile>
<renderingProfile/>
</requestProfile>
<geometryOptions>
<responseGeometryTypes>PLAIN</responseGeometryTypes>
</geometryOptions>
<waypoints xmlns:q1="http://xroute.xserver.ptvgroup.com" xsi:type="q1:OnRoadWaypoint">
<location>
<coordinate x="1286408" y="6121996"/>
</location>
</waypoints>
<waypoints xmlns:q2="http://xroute.xserver.ptvgroup.com" xsi:type="q2:OnRoadWaypoint">
<location>
<coordinate x="1118014" y="7085016"/>
</location>
</waypoints>
</request>
</calculateRoute>
</s:Body>
</s:Envelope>Code: Select all
<soap:Body>
<soap:Fault>
<faultcode>soap:Server</faultcode>
<faultstring>An internal error occurred.</faultstring>
<detail>
<ns3:XServerWebFault xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns3="http://exceptions.xserver.ptvgroup.com" xmlns:ns2="http://xroute.xserver.ptvgroup.com" hint="Restart the module or the whole PTV xServer. If the error persists, report it to PTV's xServer support and include the log files." xsi:type="ns3:InternalErrorFault"/>
</detail>
</soap:Fault>
</soap:Body>
</soap:Envelope>2019-11-21 15:12:16,581;ERROR;com.ptvgroup.xserver.xroute.router;Exceeded maximum cost.
2019-11-21 15:12:16,582;WARN;com.ptvgroup.xserver.xroute.commonServicesTasks.ServicesHelper;Caught an unexpected exception: Unsupported router error found.
