How to handle data errors?
Posted: Mon Jul 08, 2019 7:43 am
every once in a while users mention an error in the data:
If you encounter some missing data and even adapting the business logic can't help you are supposed to forward the missing data issue to
who will then take care for the internal forwarding process to data department. The colleagues will create an internal task for the incidenct and decide how to proceed.
Please provide the following mandatory info:
- a geocoding didn't find the required address
- a geocoding returns wrong coordinates for a proper address
- a street is missing
- a street's attributes are wrong, e.g.a truck attribute is missing (usually reported by drivers who weren't allowed to drive over there)
- a poi wasn't found
- the support portal
- API / software you use, e.g. PTV xServer Internet 2, PTV Developer (also with specific service URLs)
- Map version (incl. provider, e.g. HERE, subversion e.g. "2024.2H"...)
- Coordinates of the "object in charge"
- Result you expect
- Requests / responses
- Result you get
- External source of info: why do you think it is wrong? (image taken by driver, google streetview pics, official announcement , ...)
- The user. Sometimes not aware of the backend infastructure in use. He is the patient zero who reports the issue to his application provider, e.g. his own IT department or the PTV partner who integrated the software.
- The application provider: the party that implemented the business logic which accesses the xServer interface via on premise or cloud access.
- The PTV "face to the customer" (consulting/forum or support): we try to find out whether there's a quick solution (adapt business pogic) or not (data really missing)
- The PTV data department: those colleagues evaluate whether the missing data was part of the binary maps or not. If not they get back to the...
- providers (HERE, TOMTOM, ...) who delivered the raw data to PTV which created the binaries afterwards. A data provider cycle could last up to one year. In extreme situations even two!
- There's also another stage which isn't part of the schema: administration. Sometimes the data in real life has been updated, e.g. when the administration re-assings postcode areas. If providers aren't aware of such a major change it could even take more than a year to reflect the new circumstances.
