Great question! Here's how break and rest rules work across the two APIs in the context of MAY 2026 (this topic is subject to change!)
Routing API: WorkingHoursPreset
The Routing API offers ready-made presets that automatically apply regulation-compliant break/rest schedules when calculating a single route.
The WorkingHoursPreset is available in the
calculateRoutePost endpoint under the driver object. Here's the structure:
"body": {
"driver": {
"workingHoursPreset": "EU_DRIVING_TIME_REGULATION_FOR_SINGLE_DAY",
"workLogbook": {
"lastTimeTheDriverWorked": "2026-05-13T06:00:00Z",
"accumulatedDrivingTimeSinceLastBreak": 0,
"accumulatedWorkingTimeSinceLastBreak": 0,
"accumulatedDrivingTimeSinceLastDailyRest": 0,
"accumulatedTravelTimeSinceLastDailyRest": 0
These presets are not available in the Optimization API.
Optimization API: vehicle.breaks.working / vehicle.breaks.driving
In route optimization, you model break rules manually using these two parameters. You can absolutely simulate EU 561/2006 this way. Here's the documented example for a simplified single-day EU regulation:
"breaks": {
"working": [
{ "maximumWorkingDuration": 21600, "minimumBreakDurations": [900, 900] },
{ "maximumWorkingDuration": 32400, "minimumBreakDurations": [900, 900, 900] }
"driving": [
{ "maximumDrivingDuration": 16200, "minimumBreakDurations": [900, 1800] }
What this models:
| Rule | Setting | Meaning |
| Driving break | maximumDrivingDuration: 16200 (4.5h) | After 4.5h driving → break required |
| Driving break split | minimumBreakDurations: [900, 1800] | 15 min + 30 min (or one 45 min break) |
| Working break 1 | maximumWorkingDuration: 21600 (6h) | After 6h working → break required |
| Working break 2 | maximumWorkingDuration: 32400 (9h) | After 9h working → additional break |
So yes — you can simulate EU 561/2006 in the Optimization API using breaks.working and breaks.driving. You just need to configure the durations manually rather than selecting a preset. The example above is a good starting point for single-day planning.
For multi-day rest periods (11h daily rest, 56h weekly driving limits), those are only handled by the Routing API's multi-day presets and cannot be directly modeled in the Optimization API's break settings.
| Preset | Modelable? | Reason |
| EU_DRIVING_TIME_REGULATION_FOR_SINGLE_DAY | | Driving + working breaks only |
| EU_DRIVING_TIME_REGULATION_FOR_LONG_SINGLE_DAY | | Same, with extended driving limit |
| EU_WORKING_TIME_DIRECTIVE_FOR_SINGLE_DAY | | Working breaks only |
| EU_WORKING_TIME_DIRECTIVES_FOR_LONG_SINGLE_DAY | | Working breaks only |
| US_HOURS_OF_SERVICE_REGULATIONS_FOR_SINGLE_DAY | | Driving break only |
| US_HOURS_OF_SERVICE_REGULATIONS_FOR_SHORT_HAUL_AND_SINGLE_DAY |  | No breaks scheduled (short-haul exemption) — trivial |
| EU_DRIVING_TIME_REGULATION_FOR_MULTIPLE_DAYS | | Requires daily rest (11h), weekly limits |
| EU_DRIVING_TIME_REGULATION_FOR_TEAM_AND_MULTIPLE_DAYS |  | Requires daily rest, team rules |
| US_HOURS_OF_SERVICE_REGULATIONS_FOR_MULTIPLE_DAYS |  | Requires daily rest (10h) |
Here are some examples:
EU_DRIVING_TIME_REGULATION_FOR_SINGLE_DAY Break 45 min, max 4.5h driving, max 9h driving total, max 13h travel
Code: Select all "breaks": {
"working": [
"driving": [
EU_DRIVING_TIME_REGULATION_FOR_LONG_SINGLE_DAY Same as above but max driving extended to 10h (twice per week exception)
"working": [
{ "maximumWorkingDuration": 36000, "minimumBreakDurations": [900, 900, 900] }
"driving": [
EU_WORKING_TIME_DIRECTIVE_FOR_SINGLE_DAY Break 30 min, max 6h working between breaks, max 9.5h travel |
"working": [
{ "maximumWorkingDuration": 21600, "minimumBreakDurations": [1800] }
EU_WORKING_TIME_DIRECTIVES_FOR_LONG_SINGLE_DAY If working > 9h, break must be 45 min. Max 10h working. |
"working": [
{ "maximumWorkingDuration": 21600, "minimumBreakDurations": [1800] },
{ "maximumWorkingDuration": 36000, "minimumBreakDurations": [1800, 900] }
| Break 30 min, max 8h driving between breaks, max 11h driving, max 14h travel
"driving": [
{ "maximumDrivingDuration": 28800, "minimumBreakDurations": [1800] }
Important Limitations
| Routing Preset Feature | Optimization API |
| Max total driving time (e.g. 9h/11h) | Not directly enforceable via breaks — use vehicle.workingHours to limit total shift |
| Max total travel time (e.g. 13h/14h) | Same — use shift duration as proxy |
| Daily rest periods (10h/11h) | Not available |
| Weekly driving limits (56h) | Not available |
- The maximumWorkingDuration / maximumDrivingDuration settings control when breaks are triggered, but they don't cap the total driving or working time. To enforce total shift limits, combine breaks with vehicle.workingHours (earliest start / latest end).
