Feedback Loop between "planning solution" and "PTV Mira"
Space dedicated to questions about our AI driven SaaS solution PTV MIRA.
Attention: this is NOT about discussing your optimizations!
HI there,
just wanted to let you know that we have first end customers who use a combination of
  • A partner solution
  • PTV Mira
to optimize their daily planning.
Left: template for a partner solution/ Right: PTV Mira<br />As both applications access data via the same ApiKey Mira does not work on simple copy but on the original planning!
Here's an abstract description of the process:
  • First the dispatcher uses the standard partner solution with an integrated Route Optimization Optiflow API based call.
  • If there's something suspicious in the planning such as
    • unscheduled orders
    • unexpected assignment of orders to vehicles
    • whatever
    the dispatcher retrieves the JobID shown by the partner solution
  • He then asks Mira to connect to that job and analyses the output and creates alternative planning versions until he is "happy".
  • The then gathers the JobID of the planning he is happy with
  • and forwards it to the partner solution where he visualizes and perists the results
It is then possible that
  • the dispatcher uses Mira on a regular base for this process
  • the dispatcher and the partner create an updated modell of the planning based on the findings. E.g. this could lead to
    • updated parameter values (e.g. let's increase some violation costs for the area violation penalty)
    • refined data modell (e.g. let's create a new constraint that ensures... for the future plannings)
I am very happy to see that this procees gains traction!
