Will optFlow run till the time budget is totally used?
CAPcargo
Post by CAPcargo »
Hi
My question is will optiFlow claculated always till the time budget is fully consumed? Since according to the description there are only two stop scenarios. User stops or the time runs out.
But what in case all possible combinations (search space) has been already evaluated earlier?
Re: Will optFlow run till the time budget is totally used?
Hi CAPcargo,
sounds simple, but in fact the description does not completely explain the potential conditions:
  • manual interruption via stopOptimization : clear - termination is triggered and optimization comes to an end soon
  • maximum duration expired : clear - termination is triggered and optimization comes to an end soon
  • but what happens to a "small problem size" in combination with a "huge maximum duration value"?
    Example: duration set to 300secs. just one order... the algorithm spent the whole 5 minutes.
I anticipate this follow-up question related to this:
What is a meaningful "budget duration" which we could derive from an optimization's characteristics? SUch as
  • number of orders
  • number of locations (and geographic variance)
  • number of vehicles
I will forward this question to the competence center for an explanation and also to product for an improved description.
Here's some feedback I received from some Conundrian ;-)
Optimization budget duration depends not only on those variables, but also on the number of constraints that would need to be checked. If there are a lot of things that need to be taken into account during the optimization, there would quickly be a huge explosion of the problem space if you add 10 inter-order constraints.
I don't think this can be put into a simple formula to give you the optimal optimization duration. Experience with customer cases and seeing where the drop in kpi's stabilizes is the main way to establish how useful it is to optimize longer.
Sometimes customers experiment with copies of their production plannings to see if there are savings left on the table.
Typically, in practice, there is an operational constraint even on how long the plan can optimize without exhausting the problem space because they need the output.
Again, I don't see any options or need to keep track of the problem space in where the focus of the size of optiflow optimizations typically is. These are not tiny plans, and they have many constraints.
It is only "strange" for theoretical cases like this, so a self-inflicted problem, not a real one.
So what I could imagine to do is to implement some logic on client side that enables a dispatcher (or an automted process) to decide about a stop:
  • Are all orders scheduled? - for some parties this constraint is crucial and they immediately start to load vehicles once such a solution is available.
  • How much did the result improve in the last xx minutes? - Though this does not exclude a significant progress in the future this might be sufficient if you are impatient. So if the solution looks stable you might think about stopping the optimization.
at least important to know:
Concept: Optimization
You can set a preferred calculation duration, allowing the algorithm to halt automatically after the specified time. If you have a sequencing request containing only one vehicle with up to 500 orders, the calculation duration is capped at 2 minutes as sequencing requests are faster to optimize.
As announced for v1.27.0 there is a now an additional "exit" feature given via the settings.maximumStagnationDuration:
integer <int32> [ 1 .. 86400 ]
Defines the maximum duration (in seconds) the optimization may continue without improving the best-known solution. If no better solution is found within this period, the optimization will stop early - even if the overall duration limit has not yet been reached. This mechanism helps reduce unnecessary computation time when progress stalls. The stagnation timer starts when the optimization enters the RUNNING status and resets each time a better solution is found. Use with caution: This feature may prematurely terminate optimizations that could still yield better solutions given more time. Since the timing of improvements is inherently unpredictable, relying on this setting can lead to suboptimal results. It is recommended to disable this feature or set a conservative value unless you have strong reasons to limit runtime based on stagnation.
So this means if there's no progress for a certain period of time the optimization might get stopped before the settings.duration is expired.
In the context of this thread I've been asked for
What is the recommended value for Settings.Duration?
Can we built a simple function such as "INT getRecommendedDuration(int numberOfOrders, int numberOfVehicles, int numberOfLocations) which derives the duration from those KPIs?
I already started to respond to this above but let me add the following info / ideas:
Generically I see the following potential exit scenarios for a planning:
  • Users sends a deleteOptimization : user tracks KPIs and decides abot "quality of result is sufficient" (interactive). Maybe getOptimizationResult or getOptimizationProgress can provide those KPIs.
  • Client-Rule based deleteOptimization : application knows a programmatic rule which is checked everey few seconds (e.g. "if (progress.Metrics.NumberUnscheduledOrders==0) then deleteOptimitazion (jobId).
    KPIs are developing
    KPIs are developing
  • Settings.MaximumStagnationDuration : no improvement for more than xx seconds.
    Example: no progress in the last 2 minutes.
  • Settings.Duration expires : finally an optimization terminates when the total time has expired.
