linking to waypoint (zero-based index list: 1) failed
infpro_mi
Post by infpro_mi »
we are using the current xRoute Server and get the following error:
2015-10-06 08:43:17,976;INFO;RequestTimes;b1055d49-e460-4b16-972e-5f615fe8e5dc;1.2.3.4;;50030;unknown-cluster;XRoute.calculateExtendedRoute;false;;;;mg-trailer-truck;m0002;2;0;0;17;0;5;18;25;NO-TXN;;;;;;;com.ptvag.xserver.xroute.XRouteException;2530;linking to waypoint (zero-based index list: 1) failed
This error occurs only on our server. The same query works on the cloud service.
The corresponding calculateExtendedRoute query includes the ferry Langesund-Hirtshals.
The soap request looks as follows:
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><calculateExtendedRoute xmlns="http://types.xroute.xserver.ptvag.com"><ArrayOfWaypointDesc_1><WaypointDesc fuzzyRadius="10000" linkType="NEXT_SEGMENT" xmlns="http://xroute.xserver.ptvag.com"><wrappedCoords><Point xmlns="http://common.xserver.ptvag.com"><kml xsi:nil="true" /><point x="1075865.4008000002" y="8179266.7385000009" /></Point></wrappedCoords><nodeID xsi:nil="true" /><wrappedRoutingOptions xsi:nil="true" /><wrappedSegmentID xsi:nil="true" /><wrappedVehicleOptions xsi:nil="true" /><viaType xsi:nil="true" /></WaypointDesc><WaypointDesc combinedTransportID="VjEoNDc7MTEzMTg5NTMyOTs3MjsxNzU7MCkoNDU7MTEzMzIwNTgwNTsyNTQ7MTUzOzApTGFuZ2VzdW5kLUhpcnRzaGFscw==" fuzzyRadius="10000" linkType="NEXT_SEGMENT" xmlns="http://xroute.xserver.ptvag.com"><wrappedCoords xsi:nil="true" /><nodeID xsi:nil="true" /><wrappedRoutingOptions xsi:nil="true" /><wrappedSegmentID xsi:nil="true" /><wrappedVehicleOptions xsi:nil="true" /><viaType viaType="COMBINED_TRANSPORT" /></WaypointDesc><WaypointDesc fuzzyRadius="10000" linkType="NEXT_SEGMENT" xmlns="http://xroute.xserver.ptvag.com"><wrappedCoords><Point xmlns="http://common.xserver.ptvag.com"><kml xsi:nil="true" /><point x="1397455.5840000003" y="7485736.0114999982" /></Point></wrappedCoords><nodeID xsi:nil="true" /><wrappedRoutingOptions xsi:nil="true" /><wrappedSegmentID xsi:nil="true" /><wrappedVehicleOptions xsi:nil="true" /><viaType xsi:nil="true" /></WaypointDesc></ArrayOfWaypointDesc_1><ArrayOfRoutingOption_2><RoutingOption parameter="COUNTRY_ENCODING" value="ISO2" xmlns="http://xroute.xserver.ptvag.com" /></ArrayOfRoutingOption_2><ArrayOfExceptionPath_3 xsi:nil="true" /><ResultListOptions_4 binaryPathDesc="false" boundingRectanglesC="0" boundingRectanglesOffset="0" brunnelManoeuvres="false" detailLevel="STANDARD" dynamicInfo="false" manoeuvreAttributes="false" manoeuvreGroups="false" manoeuvres="true" nodes="false" polygon="true" segmentAttributes="false" segments="true" texts="true" tollManoeuvres="false" totalRectangle="false" urbanManoeuvres="false"><cenEmissionConfiguration xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" /><destDetail xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" /><emissions xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" /><hbefaType xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" /><startDetail xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" /></ResultListOptions_4><CountryInfoOptions_5 xmlns:q1="http://xroute.xserver.ptvag.com" xsi:type="q1:CountryInfoVehicleOptions" allEuro="true" calculatePartTollCosts="true" detailedTollCosts="true" namedToll="true" tollTotals="true"><q1:wrappedReductionIDs xsi:nil="true" /><q1:wrappedTollScenarios xsi:nil="true" /><q1:wrappedOptions><q1:VehicleOption parameter="TYPE" value="TRL" /></q1:wrappedOptions></CountryInfoOptions_5><CallerContext_6><wrappedProperties xmlns="http://baseservices.service.jabba.ptvag.com"><CallerContextProperty key="Profile" value="mg-trailer-truck" /><CallerContextProperty key="ProfileXMLSnippet" value="<?xml version='1.0' encoding='us-ascii'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'><Common language='de' majorVersion='1' minorVersion='0' /><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true' /><Themes><Theme id='PTV_TruckAttributes' enabled='true' /></Themes></FeatureLayer><Routing majorVersion='2' minorVersion='0'><Course><AdditionalDataRules enabled='true'><VehicleSpecific enabled='true' /></AdditionalDataRules></Course><Vehicle><Physical /></Vehicle></Routing></Profile>" /></wrappedProperties></CallerContext_6></calculateExtendedRoute></soap:Body></soap:Envelope>
This issue seems to be a server setting, because we are using the default mg-trailer-truck profile.
Are we missing the maximumDistanceToSegment or maximumDistanceToCombinedTransport xRoute server property?
Thanks!
Re: linking to waypoint (zero-based index list: 1) failed
Hello Martin,
there is a hierarchy between the various sources of parameters:
you may specify them within the snippet (as you did) or via server side.
Very important to consider:
  • parameters that do not appear in the explicit snippet may be derived from the profiles base class.
  • parameters of the xml snippet override server side parameters.
There are several potential causes for a different behaviour of of your environment and the cloud, e.g. the map data or the xml profiles.
Please get in touch with support for a detailed analysis (we can't investigate individual issues in the public forum). You may also look at the ferry ID because the ferry seems to cause the issue (index list 1). Maybe there is also a conflict between the map versions and the ID isn't known in your map?
Of course any generic statement about mechanisms is welcome,
Best regards from Madrid,
