as you know the PTV Navigator is able to use a so-called BCR file to guide a driver along a given route - this is what we call "guided navigation". Here's an example of such a string / text. Below the sample I explain different techniques of "how to assemble such a file" based on the output of different engines...
[CLIENT]
ROUTENAME=xServer 2 - guided navigation route export
MAP_VERSION=unknown
[COORDINATES]
STATION1=937170,6270123
STATION2=936043,6274708
[VISITED]
STATION1=0
STATION2=0
[Station2Segmentcenters]
Point1=936972,6269962,238
Point2=936583,6270029,350
Point3=936350,6270099,270
Point4=936080,6270359,0
Point5=934091,6272218,38
- PTV Developer: Code Sample
- xRoute2: probably the easiest way. The regular routing method calculateRoute offers a parameter resultFields which enables you to request a complete BCR text (BASE64 encoded): guidedNavigationRoute
- xRoute1: as this engine does not return a ready-to-be-used BCR you would have to write your own implementation of a BCR converter. Check the section Interface for Guided Navigation in the User Guide Guided Navigation. Or look at the famous PTV xServer Cookbook!
- MAP&GUIDE Internet: offers a feature where you can send a route straight to a PTV Navigator device once you defined the connection between M&G and the device based on the device ID.
- Other engines: probably same as with xRoute1- at least if the engine offers the required input such as coordinates.
