Specify the language in FeatureLayers
PTV Developer Raster Maps API
infpro_mi
Post by infpro_mi »
we would like to get the TruckAttributes and TrafficIncidents in a specific language.
Therefore, we have set the language property of the common element in the XMapProfile.
But the ToolTips of the Traffic Incidents and Truck Attributes are not returned in the specified language! :(
We are using the following code to add a Truck attribute layer:
var truckAttributesLayer = new XMapLayer("TruckAttributes", xmapMetaInfo.Url, xmapMetaInfo.User, xmapMetaInfo.Password) {
  CustomCallerContextProperties = new xserver.CallerContextProperty[] {
    new xserver.CallerContextProperty {
      key = "ProfileXMLSnippet",
      value = "<?xml version='1.0' encoding='us-ascii'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'><Common language='it' majorVersion='1' minorVersion='0' /><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true' /><Themes><Theme id='PTV_TrafficIncidents' priorityLevel='0' /><Theme id='PTV_TruckAttributes' enabled='true' priorityLevel='0' /><Theme id='PTV_RestrictionZones' enabled='true' priorityLevel='0' /><Theme id='PTV_SpeedPatterns' enabled='true' priorityLevel='0' /></Themes></FeatureLayer></Profile>"
  CustomXMapLayers = new xserver.Layer[] {
    new xserver.FeatureLayer {
      name = "PTV_TruckAttributes",
      visible = true,
      objectInfos = xserver.ObjectInfoType.REFERENCEPOINT
And we have used the following code to add a Traffic Incident layer in the language of Italy:
var trafficLayer = new XMapLayer("Traffic", xmapMetaInfo.Url, xmapMetaInfo.User, xmapMetaInfo.Password) {
      value = "<?xml version='1.0' encoding='us-ascii'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'><Common language='it' majorVersion='1' minorVersion='0' /><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true' /><Themes><Theme id='PTV_TrafficIncidents' enabled='true' priorityLevel='0' /><Theme id='PTV_TruckAttributes' priorityLevel='0' /><Theme id='PTV_RestrictionZones' priorityLevel='0' /><Theme id='PTV_SpeedPatterns' priorityLevel='0' /></Themes></FeatureLayer></Profile>"
    new xserver.SMOLayer() {
      name = "traffic.ptv-traffic",
      objectInfos = xserver.ObjectInfoType.REFERENCEPOINT,
      visible = true
  MaxRequestSize = xmapMetaInfo.MaxRequestSize
I believe the ToolTips of the TruckAttributes layer should be translated by the MapLocalizer.GetString(MapStringId id)(, which does not work in our case. Because the Ptv.XServer.Controls.Map.dll consists the english language in Ptv.XServer.Controls.Map.Resources.Strings.resources.
And the Traffic messages are returned in the wrong language by the xMap Server.
Martin
Re: Specify the language in FeatureLayers
Hello Martin,
I forwarded your question to DEV, hopefully my colleagues provide a sample or at least a hint to the proper DOC as soon as possible.
Yeah, meanwhile we identified the cause for the issue:
The process described by Martin refers to two non-equal containers:
  • The XML Snippet parametrizes a FeatureLayer-based resource and translates it into ITALIAN - but does not request the text messages, this is why they do not appear in the response.
  • The XMap Layer is of type SMO LAYER and is responsible for the visualization of text messages (see ObjectInfos) - but does not translate them into a NON default language. This is why they appear in the wrong language
The solution for this is:
Use one and the same container based on FEATURE LAYER to display the VIs and to request the messages in the proper language.
XML sample request image
Best regards Bernd Welter
<?xml version="1.0"?>
<Envelope xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.xmlsoap.org/soap/envelope/">
  <Body>
    <renderMap xmlns="http://types.xmap.xserver.ptvag.com">
      <MapSection_1 scale="1000" scrollHorizontal="0" scrollVertical="0" zoom="0">
        <center xmlns="http://xmap.xserver.ptvag.com">
          <point x="681142" y="6369874" xmlns="http://common.xserver.ptvag.com" />
        </center>
      </MapSection_1>
      <MapParams_2 showScale="true" useMiles="false" />
      <ImageInfo_3 format="GIF" height="400" imageParameter="" width="400" />
      <ArrayOfLayer_4>
        <Layer xsi:type="FeatureLayer" name="PTV_TrafficIncidents" visible="true" objectInfos="REFERENCEPOINT" xmlns="http://xmap.xserver.ptvag.com" />
      </ArrayOfLayer_4>
      <boolean_5>true</boolean_5>
      <CallerContext_6>
          <CallerContextProperty key="CoordFormat" value="PTV_MERCATOR" />
          <CallerContextProperty />
          <CallerContextProperty key="ProfileXMLSnippet" value="<?xml version='1.0' encoding='us-ascii'?><Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'><Common language='it' majorVersion='1' minorVersion='0' /><FeatureLayer majorVersion='1' minorVersion='0'><GlobalSettings enableTimeDependency='true' /><Themes><Theme id='PTV_TrafficIncidents' enabled='true' priorityLevel='0' /><Theme id='PTV_TruckAttributes' priorityLevel='0' /><Theme id='PTV_RestrictionZones' priorityLevel='0' /><Theme id='PTV_SpeedPatterns' priorityLevel='0' /></Themes></FeatureLayer></Profile>" />
        </wrappedProperties>
      </CallerContext_6>
    </renderMap>
  </Body>
</Envelope>
