Error while creating high performance map
darshanvp
Post by darshanvp »
Dear members,
I am having an issue while creating high performance map using attached profile.
Error I get is "The system cannot find the specified path" and then it deletes the profile file.
Any help is appreciated :) :)
MyProfile.xml
(4.35 KiB) Downloaded 350 times
KasperD
Re: Error while creating high performance map
Post by KasperD »
What exact command are you using to create hpr map data?
darshanvp
Post by darshanvp »
From xRoute/Tools/routingnetworkgenerator
Command:
routingnetworkgenerator.bat MyProfile.xml
KasperD
Post by KasperD »
Can you upload the entire /logs directory of xRoute?
Hi folks,
I recommend to handle this specific case via 1:1 helpdesk ticket and then share the cause for the error with the forum ;-)
