Hello Stefan,
this seems to be a problem of the latest autorest version, we will check this. But you can also use my sample for xServer 2.19. The generated code contains methods for all services, for example
xServer.CalculateRoute
xServer.SearchLocations
Oli
c# example res/json web API ?
- Oliver Heilig
Re: c# example res/json web API ?
Oliver Heilig
PTV GROUP - Germany
PTV GROUP - Germany
stefan.rotaru
Hello Oliver,
Thank you for the response.
Can you please give me the link where I can find the generated code for the services in xServer 2.19?
Thank you.
Thank you.
- Oliver Heilig
Hello Stefan,
you can find the generated code in the attachment at https://xserver.ptvgroup.com/forum/view ... =733#p3634
But i think i have found the problem: The latest version uses a new beta C#-generator which seems to cause this problem.
https://github.com/Azure/autorest.csharp
You can use the old (working) generator by adding a --legacy parameter. Honestly this whole Swagger/OpenAPI stuff is still in its infancy, but you should give it another try.
Oli
Oli
Oliver Heilig
PTV GROUP - Germany
PTV GROUP - Germany
stefan.rotaru
Works with --legacy parameter, thanks.
- Oliver Heilig
For your information:
Since the installation and usage of the autorest generator tool can be quite troublesome in some environments, we now also provide a download of the generated source code as part of the xServer C# client bundle.
Oli
Oli
Oliver Heilig
PTV GROUP - Germany
PTV GROUP - Germany
