Ferry from Trelleborg to Travemunde (Lubeck)
- krzysiek mbis
Is there a way to have a route from Trelleborg to Travemunde via Ferry.
I've tried many times with different settings but I can't do it.
I use the xServer .NET control and the XRoute web service to calculate the route.
Krzysiek
Krzysiek
Krzysiek Paziewski
Re: Ferry from Trelleborg to Travemunde (Lubeck)
I successfully requested the ferry:
https://xroute-eu-n-test.cloud.ptvgroup ... /ws/XRoute Depending on the balance between distance and time (OPTIMIZATION) the ferry is less attractive even with neutral ferry malus (AVOID_FERRIES) as it produces a long period.
If the OPTIMIZATION is focused on "DISTANCE" (values around 0) the neutral ferry malus also returns a FERRY route.
- krzysiek mbis
Thanks you very much.
You helped me alot.
Best Regards,
Krzysiek.
You helped me alot.
Best Regards,
Krzysiek.
Krzysiek Paziewski
Check this...
you can also seatch for potential ferries via xLocate
findCombinedTransportByLocation
The ID is then a potential property of a waypoint: Best regards,
- krzysiek mbis
Thanks,
It's working now.
Best Regards,
Krzysiek.
It's working now.
Best Regards,
Krzysiek.
Krzysiek Paziewski
- krzysiek mbis
I understand that It's all about the balance between distance and time.
But could you tell me why It's not working when I have via point in the ferry line (in the middle of the Baltic sea) ?
I'm asking because our client wants to have influance on the specyfic ferry line (for example if he has route from Oslo to Berlin). There are many possibilities for ferry lines.
What is the best way to do this ?
Best Regards,
Krzysiek
Best Regards,
Krzysiek
Krzysiek Paziewski
what is your understanding of that "VIA point in the baltic sea"? A x,y coordinate somewhere in the water close to a grey painted ferry polygon? That's probably not working.
Let's switch the perspective:
What is the requirement of the customer? He want's to enforce the routing to consider a specific ferry relation?
Check this:
http://xserver.ptvgroup.com/forum/viewt ... erry#p1303
Check this:
- krzysiek mbis
Yes, I asked about something like a x,y coordinate, but only as an example as a way to have an influence on the ferry line. But that is clear after this :
viewtopic.php?f=7&t=494&p=1303&hilit=Ferry#p1303 (I forgot about this - sorry)
But the problem with OPTIMIZATION parameter is that it will have influence on whole route. Witch can be changed dramatically!
Will this ferry ID as a potential property of a waypoint works with OPTIMIZATION parameter even if it's focused on "time" not on "distance" ?
Best Regards,
Krzysiek
- exactly what he wants.Asterix wrote:What is the requirement of the customer? He want's to enforce the routing to consider a specific ferry relation?
Best Regards,
Krzysiek
Krzysiek Paziewski
I tried to use findCombinedTransportByLocation, it works but I got different results than you. Can you tell me what parameters you used in this method? I tried:
var location = xLocate.findCombinedTransportByLocation(new findCombinedTransportByLocationRequest
ArrayOfResultField_3 = new ResultField[] { },
ArrayOfSearchOptionBase_2 = new SearchOption[] { new SearchOption { param = SearchParameter.COUNTRY_CODETYPE, value = "0" },
new SearchOption{param=SearchParameter.RESULT_LANGUAGE,value="DEF" },new SearchOption{param=ERouteSearchType.} },
CallerContext_4 = new CallerContext
wrappedProperties = new[] { new CallerContextProperty { key = "CoordFormat", value = RouteLayerExtensions.SpatialReferenceId } }
Location_1 = loc,
I tried this:
Maybe you are using a different map version?
I used maps.path=C:/PTV-XSERVER/MAPS/PTV_Europe_City_Map_Premium_2018_1H
<Location_1>
<coordinate xmlns="http://xlocate.xserver.ptvag.com">
<point x="1207690" y="7151079" xmlns="http://common.xserver.ptvag.com" />
</coordinate>
</Location_1>
<ArrayOfSearchOptionBase_2>
<SearchOptionBase xsi:type="ReverseSearchOption" value="0" param="COUNTRY_CODETYPE" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="ReverseSearchOption" value="10" param="ENGINE_TARGETSIZE" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="ReverseSearchOption" value="DEF" param="RESULT_LANGUAGE" xmlns="http://xlocate.xserver.ptvag.com" />
<SearchOptionBase xsi:type="ReverseSearchOption" value="10" param="ENGINE_MINSIZE" xmlns="http://xlocate.xserver.ptvag.com" />
</ArrayOfSearchOptionBase_2>I used maps.path=C:/PTV-XSERVER/MAPS/PTV_Europe_City_Map_Premium_2018_1H
Works, thanks for the help
Hi
I use the point geoposition and I get answers about ferries, but If I click near I get different result How that works?
Best Regards,
Marcin
Best Regards,
Marcin
Hello Marcin,
I need more details about what you do. Could you send us some screenshots (1:1 to bernd.welter@pt....)
Hello, Bernd,
I'm looking for the possibility to add custom combined transport and use it in xRoute calculations. I find this screenshot very interesting which implies that it is possible to add custom combinedTransportId?
Bernd Welter wrote: Check this...
you can also seatch for potential ferries via xLocatefindCombinedTransportByLocation
