xLocate.findCombinedTransportByLocation search parameters
Dear Bernd,
We've started implementing the xLocate.findCombinedTransportByLocation endpoint for searching for train stations (piggyback)
This endpoint has a "options SearchOptionBase[] Additional search options." parameter.
However I couldn't find anywhere in the documentation nor the forum the concrete search options for this one.
Could you help me where to find it / or send me some examples?
com.ptvag.xserver.xlocate.XLocate.findCombinedTransportByLocation
Thank you in advance!
Peter
Peter
Re: xLocate.findCombinedTransportByLocation search parameter
Hello Peter,
the class "SearchOption" is a base class from which several other classes derive their specific properties. This is visible in this diagram.
You can find som additional info in the additional usecases documentation
That paragraph mentions some meaningful ReverseSearchOptions (Parameters):
- ENGINE_TOLERANCE
- ENGINE_TARGETSIZE
- ENGINE_SEARCHRANGE
- LANGUAGE_CODE
Dear Bernd,
I'm not quite sure how to pass the search params.
We've tried different ways to pass the search options you've mentioned, but it just won't work.
We're using the API with curl, addig the params json_encoded.
The original, working code was:
We've tried sg like this:
or this:
How should we set the options param in JSON/CURL?
Thank you,
Peter
$params = [
'location' => [
'coordinate' => [
'point' => [
'x' => $xCoord,
'y' => $yCoord,
'callerContext' => [
'properties' => [
'key' => 'CoordFormat',
'value' => 'OG_GEODECIMAL',
$params = [
'location' => [
'coordinate' => [
'point' => [
'x' => $xCoord,
'y' => $yCoord,
'options' => [
'$type': "SearchOption",
'value': "-1",
'param': 'ENGINE_SEARCHRANGE',
'properties' => [
];Code: Select all
$params = [
'location' => [
'coordinate' => [
'point' => [
'x' => $xCoord,
'y' => $yCoord,
'options' => [
'ENGINE_TOLERANCE' => '160',
'ENGINE_TARGETSIZE' => '20',
'ENGINE_FILTERMODE' => '-1',
'ENGINE_SEARCHRANGE' => '-1',
'properties' => [
];Thank you,
Peter
Hello Peter,
here comes a sample - I gues you have to qualify the class name with the proper type... the ReverseSearchOption
"location": {
"coordinate": {
"point": {
"x": 10.13224,
"y": 54.32325
"options": [
"$type":"ReverseSearchOption",
"param":"ENGINE_SEARCHRANGE",
"value":"700"
"callerContext": {
"properties": [
"key": "CoordFormat",
"value": "OG_GEODECIMAL"
}Bernd Welter
Thank you! It's working this way:
One last question, which we couldn't figure out:
- all of the results are ferrys (type -> 1)
- which options do we need to set to also get back piggyback train connections?
Thank you,
Peter
'options' => [
'$type' => 'ReverseSearchOption',
'value' => '-1',
'param' => 'ENGINE_SEARCHRANGE',
'value' => '-1',
'param' => 'ENGINE_FILTERMODE',
'value' => '1600',
'param' => 'ENGINE_TOLERANCE',
'value' => '200',
'param' => 'ENGINE_TARGETSIZE',
],- all of the results are ferrys (type -> 1)
Thank you,
Peter
Hi Peter,
here's a sample that returns a train connection: the Sylt Shuttle from Niebüll (via Hindenburgdamm)
So you should be able to locate the train connections without further parameters. The challenge is more to identify whether this is a train or a ferry
"location": {
"coordinate": {
"point": {
"x": 8.82716,
"y": 54.78669
"options": [
"value":"7000"
"callerContext": {
"properties": [
}Bernd
and here comes the Channel tunnel:
"location": {
"coordinate": {
"point": {
"x": 1.17795,
"y": 51.08447
"options": [
"value":"7000"
"callerContext": {
"properties": [
}Bernd Welter
You can check the type attribute to see if something is a ferry or a piggyback (== api term for rail shuttle).The challenge is more to identify whether this is a train or a ferry
See https://xserver.ptvgroup.com/fileadmin/ ... dTransport
If i run Bernd Niebüll sample: the resulting type is 2, which according to the documentation means it is a piggyback.
"errorCode": 0,
"errorDescription": "",
"resultList": [
"id": "VjEoNDk7MTEyNjQ1NTEzNjsxNzI7MjEwOzApKDQ5OzExMjMzMDk0Mjg7MTI3OzE5MDswKU5pZWLDvGxsIC0gV2VzdGVybGFuZA==",
"name": "Niebüll - Westerland",
"duration": 3401,
"distance": 1089.407079898105,
"type": 2,
"start": {
"coordinate": {
"$type": "Point",
"point": {
"$type": "PlainPoint",
"x": 8.8404412179,
"y": 54.780580254
"country": "D",
"name": "Niebüll"
"destination": {
"coordinate": {
"$type": "Point",
"point": {
"x": 8.3111510833,
"y": 54.906602861
"country": "D",
"name": "Westerland"
"combinedTransportFields": []
}Joost Claessen
Hi Bernd, Hi Joost,
Thank you! It's ok now. Your examples are valid.
We just need to channel these ids to the routing engine.
Thank you for the help!
Peter
Peter
