Unfortunatelly for the SDK not all fields are considered from the BCR. As you can read here, the navigation will always start with the first station of the BCR file, independent of the attribution of the visited field:
http://navigator.ptvgroup.com/DE/sdk/na ... ec399dc68c
"Attention: The start station of the tour will be set to the first station in the file ("STATION1"). All following stations in the file will be handled as destinations. SVP points are supported and will be properly added to the tour."
Also when you want to save a tour, visited will be ignored:
http://navigator.ptvgroup.com/DE/sdk/na ... 72502afa87
"Attention: "STATION1" in the BCR file will be set to the start station of the tour. All other stations of the tour will be written in the order of appearance. Also, the BCR format has much more fields which are not filled by SDK_SaveTour, only values in SDK_Waypoint and SDK_SVPWaypoint will be saved (e.g. the skipped flag will not be set in the BCR). SVP points are supported and will be properly written."
