- xRoute 2 : TourStopOptions
The current v2.24 version mentions a "The service time."
In this version the service is always ACTIVE, not passive - maybe we implement a switch later... - xTour2: Service is always "active". The length of a service period is maintained
- through the Site class
- or via the TransportOrder class or the VisitOrder class
- or via the Vehicle class
- PTV Developer Route Optimization Optiflow : In the context of 17.10.2024 DAPI does not support passive service. This might be subject to change.
Service time: active versus passive
Service times at stops...
Re: Service time: active versus passive
With xRoute 2.33 we invented a new property at TourStopOptions:
- Boolean useServiceTimeForRecreation (optional, default=false)
- Tells if the service time could be used for a break/rest period. In this case, the driver is not working and the service time is not considered as working time. Please note that this parameter is only considered if the service time is greater than 0 second.
