AjaxMaps debug Popup
i.kobeissy
Post by i.kobeissy »
We are using ajaxMaps in our application, lately with Chrome browser we are getting a debug popup that popup up when loading a screen with an embedded ajaxMaps. It's not systematic, we don't have a pattern for reproducing the case. so my question is, is it possible to prohibit the showing of this popup ?
Regards
Re: AjaxMaps debug Popup
Hello Ibrahim,
I forwarded this to the developer of the AJAX control - I hope he responds soon.
If not: get back to me 1:1!
AndreasJunghans
Post by AndreasJunghans »
Hello Ibrahim,
what's the contents of this popup?
Andreas
i.kobeissy
Hello Andreas,
The popup contains the following lines
000750 DEBUG: qxp.core.Init[3]: qooxdoo 0.6.2-pre (r4314)
000771 DEBUG: qxp.core.Init[3]: loaded 40 classes
000773 DEBUG: qxp.core.Init[3]: client: webkit-537.36/win/en
and here's a screenshot of it
debugPopup
debugPopup
AndreasJunghans
This looks like a symptom of another problem. Usually, this is what happens:
1) Some basic infrastructure is set up, including logging (default log level is "debug").
2) The actual map code is loaded, which sets the log level higher.
3) In the onload event, some debug logging is performed (what you see in the popup), but it should be suppressed because of step 2.
So I think the actual problem is some error in step 2. Could you take a look at the JavaScript console to see which errors are printed there when the popup appears?
i.kobeissy
Hello Andreas
thanks for your answer, in fact you are right I found that we have errors in the console when the popup is shows
Uncaught TypeError: vRequest is null
Uncaught ReferenceError: qxp is not defined
so I will try to solve this issue inside our application
Thank you
