We encountered the problem of wrong ISO Code 3 for Romanian leu - Romania currency is returned from PTV xRouteServer. Actually ISO Code 3 should be RON. However, in CountryInfo.Currency code we are getting it as ROL.
So how can this be corrected?
Thank you
Currency Romanian leu - Romania code ROL
Niren Patel
Core Developer
BRABENDER tech
Niren Patel
Core Developer
BRABENDER tech
Re: Currency Romanian leu - Romania code ROL
Hello Niren,
I created a bugtracking task (MPXSRV-4404). Looks like we have an issue here
Now we need a feedback from DEV.
Any timelines by which we can expect response from DEV.
Thanks
Thanks
Niren Patel
Core Developer
BRABENDER tech
Niren Patel
Core Developer
BRABENDER tech
at least I have a feedback from a consulting colleague (Thanks Joost!):
Please consider to switch to the recommended property,The countryInfo.currency is deprecated. It is an enumeration so we cannot change this without breaking backwards compatibility. The customer should use currencyISOCode, which is returned if you set countryInfoOptions.currencyDescription=true in your input. The currencyISOCode is correct.
I tried setting countryInfoOptions.currencyDescription=true while calling calculateExtendedRoute().
However, getting currencyISOCode as null in response.
Is their any sample which I can check to see what am I missing for this?
Thanks
Thanks
Niren Patel
Core Developer
BRABENDER tech
Niren Patel
Core Developer
BRABENDER tech
here's a sample JSON... Maybe a bit oversized (Budapest to Bukarest)
Here's also the response:
"waypoints": [
"$type": "TourPointDesc",
"linkType": "AUTO_LINKING",
"fuzzyRadius": 0,
"coords": [
"$type": "Point",
"point": {
"$type": "PlainPoint",
"x": 2902433.3262,
"y": 5526905.5204
"fuzzyRadius": 0,
"coords": [
"$type": "Point",
"point": {
"x": 2117212.5605,
"y": 6017026.8256
"options": [
"parameter": "REQUEST_VERSION",
"value": "1.6"
"parameter": "COUNTRY_ENCODING",
"value": "ISO2"
"parameter": "ROUTE_LANGUAGE",
"value": "EN"
"parameter": "DISTANCE_MEASURE",
"value": "KM"
"exceptionPaths": null,
"details": {
"manoeuvres": false,
"texts": false,
"nodes": false,
"binaryPathDesc": false,
"polygon": false,
"polygonElevations": false,
"detailLevel": "STANDARD",
"dynamicInfo": false,
"segments": false,
"segmentAttributes": false,
"segmentAttributePiggyback": false,
"manoeuvreAttributes": false,
"brunnelManoeuvres": false,
"urbanManoeuvres": false,
"manoeuvreGroups": false,
"tollManoeuvres": false,
"boundingRectanglesC": 0,
"boundingRectanglesOffset": 1000,
"totalRectangle": false,
"extSegments": false,
"speedLimits": false,
"featureDescriptions": false,
"utcOffsets": true
"countryInfoOptions": {
"$type": "CountryInfoVehicleOptions",
"detailedTollCosts": false,
"allEuro": false,
"calculatePartTollCosts": true,
"namedToll": true,
"tollTotals": true,
"currencyDescription": true,
"waypointIndexInTollCostInfo": true
"callerContext": {
"properties": [
"key": "Profile",
"value": "truckfast"
"key": "CoordFormat",
"value": "PTV_MERCATOR"
"$type": "ExtendedRoute",
"route": {
"info": {
"distance": 831805,
"time": 44433,
"cost": 540349
"stations": [
"$type": "WayPoint",
"accTime": 0,
"accDist": 0,
"iuCode": 40,
"polyIdx": 0,
"nodeIdx": 0,
"segmentIdx": 0,
"manoeuvreIdx": 0,
"locationCoord": {
"$type": "Point",
"point": {
"x": 2902428.6809,
"y": 5526904.9147
"matchCoord": {
"$type": "Point",
"point": {
"x": 2902433.6999,
"y": 5526905.3336
"wayPointType": "START",
"countryCode": "RO",
"utcOffset": 180
"accTime": 44433,
"accDist": 831804,
"iuCode": 36,
"polyIdx": 4864,
"nodeIdx": 3536,
"segmentIdx": 2302,
"manoeuvreIdx": 29,
"locationCoord": {
"$type": "Point",
"point": {
"x": 2117208.2621,
"y": 6017026.2036
"matchCoord": {
"$type": "Point",
"point": {
"x": 2117212.7982,
"y": 6017026.1125
"wayPointType": "DEST",
"countryCode": "HU",
"utcOffset": 120
"countryInfos": [
"iuCode": 40,
"partRouteInfo": {
"distance": 613653,
"time": 33152,
"cost": 0
"currency": "ROL",
"currencyName": "Romanian Leu",
"currencyISOCode": "RON",
"additionalInfo": "",
"tollName": "",
"tollTotals": {
"distance": 0,
"cost": 0
"perNCRouteInfo": [
"distance": 453470,
"time": 20659,
"cost": 0
"distance": 148420,
"time": 11227,
"cost": 0
"distance": 10635,
"time": 1063,
"cost": 0
"distance": 1128,
"time": 203,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
"perTypeTollDistance": [
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"perTypeTollPrice": [
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"iuCode": 36,
"partRouteInfo": {
"distance": 218151,
"time": 11281,
"cost": 204202
"currency": "HUF",
"currencyName": "Hungarian Forint",
"currencyISOCode": "HUF",
"tollName": "",
"tollTotals": {
"distance": 204360,
"cost": 1062783
"perNCRouteInfo": [
"distance": 204935,
"time": 9687,
"cost": 204202
"distance": 0,
"time": 0,
"cost": 0
"distance": 8238,
"time": 789,
"cost": 0
"distance": 4301,
"time": 642,
"cost": 0
"distance": 677,
"time": 163,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
"distance": 0,
"time": 0,
"cost": 0
0,
204360,
0,
0,
0,
0,
0,
0,
0,
204360,
0
0,
1062783,
0,
0,
0,
0,
0,
0,
0,
1062783,
0
"partTollCosts": [
"distance": 204360,
"costs": [
"cost": 1062783,
"currency": "HUF",
"iuCode": 36,
"type": "NATIONALTOLL"
I tried setting coutryInfoOptions as per the sample you provided.
Still the currencyISOCode in response is null. Not sure why!!.
Is their any configuration required in PTV xServer. We are using xServer version 1.24.
I will give it one more try, and will get back to you.
Thanks
Thanks
Niren Patel
Core Developer
BRABENDER tech
Niren Patel
Core Developer
BRABENDER tech
It worked. Thanks for the help.
Niren Patel
Core Developer
BRABENDER tech
Niren Patel
Core Developer
BRABENDER tech
