[JS - Leaflet] Convert GDF Time Domain to a readable value
stunty
Post by stunty »
I m using Leaflet to render the PTV map with Traffic Incidents & co.
On Traffic Incidents popups, there is a time/duration value written like that :
time Domain: [(y2019M10d31h6m52s30){h1m2s30}]
relevant By Time: true
Is there a function that can convert that to a more readable string ?
I have found these docs too but I m lazy to develop my own function if something else already exists...
https://xserver2-dashboard.cloud.ptvgro ... omains.htm
https://china.cloud.ptvgroup.com/manual ... omains.htm
Thank you very much in advance
Re: [JS - Leaflet] Convert GDF Time Domain to a readable value
Hm... that's a challenge. The documentation of the xServer2 seems to be buggy: the link to the external reference of the party that specified the style is not valid. I asked my colleagues to provide a new link...
YellowFoxNP
Post by YellowFoxNP »
Hi here is my implementation. It's not complete and not bulletproof at the moment but i hope it's a good start for you:
function parseTimeDomain( input )
   var tmp = input.split( /[()]+/ );
   var result = {};
   if( tmp.length >= 3 )
      result.startDate = parseDateByGDF( tmp[1] );
      if( tmp[2].indexOf( '{' ) > -1 )
         result.endDate = parseEndDateByGDFDuration( tmp[2].split( /[{}]+/ )[1], new Date(result.startDate.getTime() ) );
   if( tmp.length == 4 )
      result.endDate = parseDateByGDF( tmp[2] );
   return result;
function parseDateByGDF( parse )
   parse = parse.split( /[A-Za-z]/ );
   if( parse[5] < 10 )
      parse[5] = '0' + parse[5];
   if( parse[6] < 10 )
      parse[6] = '0' + parse[6];
   return new Date( parse[1] + '-' + parse[2] + '-' + parse[3] + ' ' + parse[4] + ':' + parse[5] + ':' + parse[6] ) ;
function getDateInGermanFormat( date )
   var day = date.getDate();
   var month = date.getMonth();
   if( day.toString().length == 1 )
      day = '0' + day;
   if( month.toString().length == 1 )
      month = '0' + month;
   return  day + '.' + month + '.' + date.getFullYear() + ' ' + date.toLocaleTimeString( 'de-DE' );
function parseEndDateByGDFDuration( durationString, date )
   var tmp = durationString.split('');
   var type = '';
   var value = '';
   for( var i = 0; i < tmp.length; i++ )
      if( tmp[i].match( /[a-zA-Z]+/ ) != undefined )
         if( type != '' )
            setIntervalByType( type, parseInt( value ), date );
         type = tmp[i];
         value = '';
      else
         value += tmp[i].toString();
   if( type != '' )
   return date;
function setIntervalByType( type, value, date )
   if( type == 's' ) date.setTime( date.getTime() + ( value * 1000 ) );
   if( type == 'm' ) date.setTime( date.getTime() + ( value * 1000 * 60 ) );
   if( type == 'h' ) date.setTime( date.getTime() + ( value * 1000 * 60 * 60 ) );
   if( type == 'd' ) date.setTime( date.getTime() + ( value * 1000 * 60 * 60 * 24 ) );
   if( type == 'w' ) date.setTime( date.getTime() + ( value * 1000 * 60 * 60 * 24 * 7 ) );
   if( type == 'M' )
      date.setMonth( date.getMonth() + value - 1 );
   if( type == 'y' )
      date.setFullYear( date.getFullYear() + value );
Thanks for your implementation, Nico,
In the meantime I raised a new JIRA (XS-3574) that requests a proper documentation of the format despite the broken link to the external documents.
Have a nice christmas time!
s.warnat
Post by s.warnat »
Hy,
I know it is an old thread, but the one found by Google.
We extended the leaflet-xserver repo by an almost complete, german only, TimeDomain parser here, which we will provide for general usage:
It can also be used standalone, without the leaflet library, but is included into the new customized.html example.
There are some easy examples how to use the library
We never worked with the browserify library, that's why created the easy way.
We will prepare the merge request, to make it available for all developers to be extended and maybe to implement some more "special cases" to improve understandability.
Regards!
Attention:
In the context of the GDF Time domain more and more often we get asked for the readable format.
In PTV Developer we offer some solution for this requirement based on the VectorMaps.
Check this Showcase Map Rendering and Geocoding (as of march 2024: english only)
Here are some examples:
Städtisches Klinikum Karlsruhe (no trucks at night time)
Some fancy restrictions at teh french-spanish border near Canejan
